Results 1 to 3 of 3
01-10-2014, 05:06 AM #1Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
What's the best engine oil for a flat tappet cam.
I have several old school cars and I have heard that zinc and other additives have been removed from engine oils,All of the cars have less than 20,000 miles on them so I want a good oil that will keep them running for a long time.what oil have some of you found really makes a difference in none roller cam engines?
01-10-2014, 07:27 AM #2Pontiac Builds Excitement
- Nov 2005
- NC
Sunset Orange Metallic- 2002 Pontiac TransAm WS6
I have had great results using Shell Rotella 15w40 in my 67 Pontiac GTO with a 400ci. It's considered a HD diesel oil but does still have the minimum recommended additives that these engines need.
01-10-2014, 01:04 PM #3Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
That's the oil that I have been using in my cars and had never had a problem until this week,I have to replace the cam and lifters, I can't say that it came from using the Rotella because I rebuilt the engine about 13 years ago. I use it in all of my cars and not one problem until now.I feel that it was something I my not have done when breaking in the engine.I plan on staying with the Rotella until I hear of something better.I was a diesel mechanic until I retired 6 months ago,Rotella was what we used in all of our trucks big and small.thanks for the OK on this oil I was wondering if I was the only one using it.
Solid, Hydraulic, Flat-Tappet, and Roller Cams - How It Work
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 05-06-2013, 06:20 PM -
Flat-Tappet Cams and Worn Down Engines - The Perfe
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 08-09-2010, 05:40 PM -
Help: Engine surge/flat spot 2k-3k rpm
By bcorwin in forum General HelpReplies: 16Last Post: 08-29-2009, 11:56 AM -
Flat Tappet Cam Tech - Righting the Wrongs
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-20-2006, 04:59 AM -
3200RPM, temp gauge flat lines & engine bogs out
By third_shift|studios in forum General HelpReplies: 30Last Post: 02-19-2006, 03:38 PM
