Results 1 to 20 of 36
    Member 79Firebird_99TA's Avatar
    ATL
    99 Trans Am
    Life Expectancy for the LS1
    I've been wondering how long I can expect my engine to last. It's at 260,000 and still runs great. I use a quart of oil between oil changes (3,000 miles). Other than that, and a little piston slap on a really cold day's first crank, I have no issues. The engine is also bone stock.
    Dec 2013
    East side Wisconsin
    Some kind of silver
    99 SS, Slp #1273... 08 gt
    As long as its taken care you wont shouldn't have any problems for years to come. i have seen one with 300k-ish. Motors are stout to begin with.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    I have a friend with a 2000 Z28 that he uses as a daily drive and he has been putting in a quart between oil changes for years. He is waiting for the engine to blow so that he can build his dream engine but his LS1 is not cooperating and now he has 382k and he still get over 20mpg. Proper maintenance and normal driving habits are key to long life in any engine. My friend think he can get 500k out of his Z.
    Member freaky57fast's Avatar
    Feb 2013
    michigan
    2002 WS6 A4, 2010 ram
    I have 35k and I use oil between 3000 mile changes I'm looking at a catch can... sounds like you'll never need to swap yours out, unless you want to...
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    69,000 and mine spun a bearing.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by cpop98ws6 View Post
    My T56 broke at 12,000 miles . It happens.
    ATL
    99 Trans Am
    Encouraging posts except for the t56 and the spun bearing. I've never really dogged mine ... it's been my DD since day one. If I still have the car when the engine dies, I'll stick an LQ9 in her.
    Member Decadence75's Avatar
    Aug 2013
    Missississipi
    Bright Red
    2000 Trans Am
    Those of you using a quart inbetween changes, really look into re-doing your PCV systems. That is there your extra oil is going, right into your intake. I would suggest moving to an 04+ valley cover with a catch can as additional insurance.
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Quote Originally Posted by Decadence75 View Post
    Still will eat some oil regargless. I have both and I know some who have both and it still eats some oil.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    ATL
    99 Trans Am
    Not too worried about that quart. I think what I'll start doing is add one quart at 1500 miles (after oil change). I hate it when that low oil light comes on at 2500 or so miles after oil change. Almost feels like a waste knowing that I'm going to be changing the oil in a week to 10 days.
    `99 Trans Am: Vigilante 2600, Stroked (383), Cammed, TSP Catback and Headers,Strano/Koni STR.T, Strano 35/22 Sway Bars, Elite E2 Catch can, 400,000 miles
    79 Firebird: Pontiac 400 4-speed, Borg Warner Super T-10, XE-268 Cam, Hedman headers, Edelbrock RPM intake, dual exhaust & Flowmasters
    `08 Corvette Base M6 LS3, Morimoto Headlights and Taillights, SLP Blackwing CAI.
    Silly question, but how much oil do you put in it to fill it up? Including the oil filter.
    ATL
    99 Trans Am
    5.5 quarts.
    I figured that would be your answer as I know you are pretty up to speed on things. Just wanted to check.
    ATL
    99 Trans Am
    Thanks man ... I figure I'd better have an idea ... or a deep pocket - LOL .... not to mention, the thought of some shop's hands on my TA would feel like some form of molestation.
    Junior Member Oceanside78's Avatar
    Jul 2012
    Fayetteville, NC
    I feel like I burn oil at WOT, but my level never really seems to change. I have leaks all over the place though, so it's probably PS fluid or trans fluid or brake fluid...or....lol
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Iam at 84,xxx and dont burn any oil. I drive my car hard, but only on nice weekends. I prob dont put 3k a year on it. I did however notice before the pcv delete, I did use a bit of oil. Now with the oil breather set up, it def seems to have helped if not eliminate my oil consumption.
    Jul 2012
    Fayetteville, NC
    Quote Originally Posted by RONS98TA View Post
    Do you have a write up or link to what this is? If like to do this
    MARYLAND
    BLACK
    1998 PONTIAC TA
    I dont have a link or write up, but iam sure some of the other more computer savy peeps on here will have that info. In a nut shell, it just takes the tubing coming off of the valve covers and re-directs it to a different location other then the intake manifold. Most use a breather tanks (ww.summitracing.com/search/part-type/oil-breather-tanks?SortBy=Default&SortOrder=Ascending&tw=breath er%20&s) The org factory design sucks oil from the valve covers into the intake then into the motor. This not only sucks oil from the engine, but will also lower your fuel octane rating from lets say (this is just an estimate for example) 93 to 90.
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    Quote Originally Posted by Oceanside78 View Post
    http://www.ls1.com/forums/f48/pcv-ca...ressure-81389/
    99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
    Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
    Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
    Wish list.
    Coil overs, Heads & Cam
    Jul 2012
    Fayetteville, NC
    Thanks to both of you!! Looks like I have a larger "need" list now lol
  1. Question: Life expectancy of 4L60E
    By thomasterrible in forum Automatic Transmission
    Last Post: 05-27-2010, 10:47 AM
  2. 4l60E life expectancy?
    By scubamark3995 in forum Automatic Transmission
    Last Post: 08-19-2009, 05:58 PM
  3. LS1 engine life expectancy
    By azzkikr in forum Camaro / SS
    Last Post: 03-17-2009, 06:37 PM
  4. A4 life expectancy
    By speedracer1280 in forum Drivetrain
    Last Post: 03-15-2007, 07:42 AM
  5. life expectancy of Eibach/bilstein setup
    By kickarss in forum Suspension and Handling
    Last Post: 12-07-2006, 08:48 AM
