    hitchcock, texas
    1978 280z- ls1-v8
    4l60E life expectancy?
    I just had my tranny rebuilt. I thought I recieved the whole upgrade. All I got was a rebuild with a shift kit. I am building a 383 ls1 with about 530 hp give or take. My car ways about 2900lbs. I will be using a cirle D 3700 stall converter with a 2.5 STR. How long should I expect the tranny live? I have nittos and it will basically only be driven on weekends and at the track.
    Junior Member kaine806's Avatar
    Jul 2009
    Lubbock TX
    97 e36 m3
    does it have the stock clutch pack's?
    it's a toss up eather way... a stock 4l60 is only rate to handle 350hp I beleave..
    hitchcock, texas
    1978 280z- ls1-v8
    Yeah. I am being told that it will break pretty quick and possibly ruin my brand new converter. The tranny only had 38000 miles on it. I expect they did basic wear replacement on parts and added a shift kit . Now I have to pay $2000 to get it right at century transmission. It doesn`t even have fluid in it yet.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Get the beast sun shell because that will break way before the clutch pack goes out. and then do a good clutch pack, 2-4 band, Servo at the least. Shouldn't cost that much to have someone go in and replace those parts.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    I'm still running the original 4l60e in my 98. I have the beast sunshell and HD clutches with a 4600 stall. Been racing it for a good 8 years now.
    It will last forever !!! LOL, I better go knock on some wood now !!!
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    lol yea some OAK
    Jul 2009
    Lubbock TX
    97 e36 m3
    I have the raybestos clutch pack's, the beast sunshell, a heavy duty 2-4 band and 5 pin planet's in my 4l60 the clutch's grad hard and hold firm... it's worth the money...
    here's the front planet
    Here's the rear planet.
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    Quote Originally Posted by JaycenK View Post
    You don't need extra power to break the sun shell. Mine went with 38,000 miles and no mods at that point.
    hitchcock, texas
    1978 280z- ls1-v8
    I dropped off my tranny over the weekend at circle D and picked up their 3600 stall converter.
    Member fieropope's Avatar
    union mo
    01 formula
    ok for any one who plans on racing their automatic f-body and wants to not ever worry, heres what you need: the beast sun shell (no other replacement even comes close),Z-pac raysbestos cluthes & colene steels,super servo,5 pinion planetaries front and rear,shift kit(transgo is what ive used most),trans cooler (biggest you can fit),stall (depends on engine spec.),hardend inner sprag race ,and im working on making a billet pump rotor which is the last weak point in this trans,other than the input and output shaft.so after you put this in your trans youll probly need a new rear but youll never have to worry about the trans again . hope this helps
    Jul 2009
    Lubbock TX
    97 e36 m3
    here's what I have in mine...
    it shift's very fast and smooth with a 2000stall...
    ▪ Rear Heavy Duty 5 Pinion Planetary
    ▪ Front Heavy Duty 5 Pinion Planetary
    ▪ (3) Molded Pistons
    ▪ 4L60E Corvette 2nd Gear Servo
    ▪ 4L60E Super Servo 4th Gear Cover
    ▪ 4L60E Alto Wide High Performance Band
    ▪ Teflon Pump Bushing
    ▪ Delco Front Seal Retainer Clip
    ▪ Hardened Pump Rings
    ▪ 4L60E 13 Vane Rotor Gear
    ▪ 4L60E 13 Vane Rotor Guide
    ▪ 4L60E 13 Vane High Rev Kit
    ▪ Heavy Duty "Beast" Sun Shell
    ▪ Heavy Duty 29 Element Sprag
    ▪ Heavy Duty Wide Rear Sprag
    union mo
    01 formula
    Quote Originally Posted by kaine806 View Post
    theres a bulletproof trans ,the front seal retainer is kinda useless but hey why not throw it in lol
  1. Life Expectancy for the LS1
    By 79Firebird_99TA in forum General Help
    Last Post: 01-10-2014, 06:14 PM
  2. Question: Life expectancy of 4L60E
    By thomasterrible in forum Automatic Transmission
    Last Post: 05-27-2010, 10:47 AM
  3. LS1 engine life expectancy
    By azzkikr in forum Camaro / SS
    Last Post: 03-17-2009, 06:37 PM
  4. A4 life expectancy
    By speedracer1280 in forum Drivetrain
    Last Post: 03-15-2007, 07:42 AM
  5. life expectancy of Eibach/bilstein setup
    By kickarss in forum Suspension and Handling
    Last Post: 12-07-2006, 08:48 AM
