Results 1 to 20 of 23
Thread: Oil service
    Jun 2012
    florida
    Oil service
    If the oil service screen comes on a few times will it shut down the car. It did on mine. When I reset the service indicator the car started
    First I have heard of this.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    I never heard of that happening on any car, I was probably just a coincidence.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Never heard of it and I've had mine for almost six years. Have your car scanned. Could be a body control module issue.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    It could be some type of engine protection code but I have never heard of this on any car. I would have it scanned just to be on the safe side.
    Jun 2012
    florida
    Obdii
    I did scan it with an ODBII scanner but you know thats an emmission code scanner for the most part and those issues wont cause the car to stop running. ie if your water pump goes out do you think an obdii scanner will tell you? People also have told me that these cars dont have a panic alarm but I know they do. I pressed the buttons one day a certain way and the alarm went off. So I tried to start it 3 times, pausing each time, would not start, rest the oil indicator then it starts. Coincidence? The dealer replaced the BCM about a year ago and have had no problems except for this incident.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    Call your GM dealer.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    Was the security light on while cranking?
    Jun 2012
    florida
    BCM
    I am thinking when you are cranking all the lights come on as a test. Not sure which one is a security light. When I was cranking the car over, it felt like it was trying to start but died. One time I pressed the accellerator down when cranking and nothing happened. Are you thinking the BCM and when it causes trouble does the entire BCM functions go out. ie should I have tried the remote door locks?
    North Jersey
    2004 GTO M6
    I'm wondering if when you pressed the buttons on the fob, you possibly wiped the memory from the fob. I know the fob contacts the ring on the lock cylinder to permit coding/starting. You might have reset something when you reset the service light. I could be wrong as I have never pressed the buttons like you did. Our security light is a flashing padlock on the lower left hand side of the gauge cluster.
    Jun 2012
    florida
    alarm
    The alarm incident happened a year ago and the fob still worked fin, along with the car. I dont think anything got wiped out. Next time it happens I will put a timing light on a spark plug wire to see if its a firing problem. I heard a bad BCM can prevent the car from starting. I thought the body control module would be for things like the door locks and lighting.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    Might have an ignition relay going bad.
    Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq [email protected].
    North Jersey
    2004 GTO M6
    Bad BCM will disable the ignition system on our cars. Our BCMs run a lot of other systems on our cars.
    Ignition
    Interior/exterior lighting
    ABS/Traction Control
    Anti-theft
    Radio
    Gauges
    Air Conditioning
    The BCM allows all the different on-board systems to communicate with each other. It goes bad and the car can be rendered pretty much useless.
    Just curious, other than a super salty Tech II, is there a reasonably priced BCM scanner out there?
    Jun 2012
    florida
    BCM
    Well, it looks like the BCM, although its new. Called the dealer who has the full history on the car and had replaced the BCM and they said its a security issue, security light is blinking when its not starting. Its under an extended warranty and its covered (they said) so I hope it can be fixed and my starting problems ended.
    Just do the VATS bypass and be done with it.
    Jun 2012
    florida
    Vats
    Bypass a VATS on a GTO, never heard of that, how is that done?
    I was posting mobile when I replied and did not see that we were in the GTO sub-forums.
    North Jersey
    2004 GTO M6
    I believe a Solus/Modus or Autell scanner can scan BCMs.
    Quote Originally Posted by johnfin View Post
    Good to hear you don't have to pay out-of-pocket. Once the replacement BCM goes in and is coded to the new fobs, you'll be back on the road with no further worries.
    Jun 2012
    florida
    BCM
    Not really, its been done recently, new BCM, keys and programming, no luck. For the most part the car is ok, 2 times it has not wanted to start.
  1. Thank You for your service.
    By 2000 SS Beast in forum Almost Anything Goes
    Last Post: 11-11-2008, 06:51 PM
  2. Gamester did not do service
    By Bigrus in forum Political / Debate Forum
    Last Post: 08-21-2008, 07:44 AM
  3. service engine soon!
    By eatsrice in forum General Help
    Last Post: 03-10-2008, 07:02 PM
  4. Service Engine Soon
    By 2001bird in forum General Help
    Last Post: 10-18-2006, 04:40 PM
  5. Service Engine Soon
    By sav ga ss in forum General Help
    Last Post: 10-03-2006, 05:53 PM
