    Member 99yellowz28's Avatar
    akron,oh
    competition yellow
    1999 camaro m6
    Part number for ls6 intake manifold
    I was wanting the gm part number for a ls6 intake manifold and is it its direct bolt on or is there other things that need done my car is is a 99 z28 and has the egr stuff still on it with Hooker headers
    here you go. this thread has most of the info you need
    http://www.ls1.com/forums/f63/how-do...intake-126647/
    While doing this I would update the knock sensors while you have the intake off.
    You can kill the egr & air pump stuff and block off the egr plates on the headers. A mail order tune from Frost will take care of any codes from this.
    Intake swaps are easy enough to do. Just be careful when the intake is off to not drop anything in the heads or you'll be fishing or pulling heads.
    A couple of areas to pay attention too:
    1) OPSU sits just behind the drivers side of the intake. Many ppl on their first time removing the intake forget about it and break it, usually with the break booster hose. Just move the hose around it carefully and you should be fine. Once you are back together if you have no oil pressure this is what you'll need to replace. Cost about $58 and the $10 socket is worth it.
    2) HVAC tubing comes off the back of the intake near the map sensor. It is a PITA to attach it back on but it is need in order to use your HVAC system. Just don't forget about it.
    also forgot to add the fins on the bottom of the ls6 intake will have some issues with the ls1 coolant bypass lines. you can knock them off or get the ls6 coolant kit.
    Junior Member JROBINSON1016's Avatar
    NORTH CAROLINA
    RED
    1998 TRANS AM
    ls6 intake gm part number- 88894339
    gmpartsdirect.com
    or go to your local gm dealer
  1. For Sale: LS6 Z06 Intake Part Number 12573572
    By bigboykilroy in forum Parts For Sale / Trade
    Last Post: 11-19-2009, 05:06 AM
  2. GMPP L92 Carb intake Part number 25534416 with int
    By 94form2000z in forum Cowhands, Local Parts and Fish Bait
    Last Post: 08-04-2009, 03:02 PM
  3. LS1 intake manifold part
    By carjunkie in forum General Help
    Last Post: 05-05-2009, 08:09 PM
  4. is this the GM part number for the LS6 intake kit?
    By snake_skinner00 in forum General Help
    Last Post: 03-11-2006, 12:02 PM
  5. intake part number
    By mxkx250 in forum External Engine
    Last Post: 08-19-2005, 05:28 PM
