Results 1 to 3 of 3
Thread: steeringwheel shaking only at 55
04-14-2006, 10:05 AM #1
- philadelphia
red- 2000transam
Hello, i have a 2000t/a and a vibration problem at the speed of 55, first let me say that i notice this problem around15,000 miles before any work was done and the car only has 25,761 and seem to be shaking a little more more.I had the stock original wheel and tires 245/50/16 balance and rotors cut at the dealers.I recently intall the prokit and koni s/a, sams 35/22 bars.If i go under 55 or go over 55 the vibration goes away . I'm also using the american rebel wheels at the moment with kdw2 275/35/18 and there no differents with these or the stockers.I had the alignment done after the upgrade.any help is appreciated thankyou.
04-14-2006, 05:54 PM #2
- Tulsa,OK
Quick Silver- 2002 Z06
If you have had your wheels balanced I would look at tie rod ends. Inner or Outer could cause this. Outer are cheaper. You should be able to jack it up and try to wiggle the wheel left or right and detect any slop in them if there is any.
04-14-2006, 09:06 PM #3
- philadelphia
red- 2000transam
Hello, ok driverside has a good bit of slop and i can feel play and light popping feel to it on the inner side towards the motor. This is the problem thanks for your help.
my car is shaking
By camaronoob in forum V6Replies: 15Last Post: 07-01-2010, 06:05 PM -
Steering shaking
By BirdCountry02 in forum Suspension and HandlingReplies: 8Last Post: 03-12-2010, 07:50 PM -
What's shaking
By Golicous in forum New Member IntroductionsReplies: 3Last Post: 05-20-2009, 01:23 AM -
steeringwheel controls
By yodabill in forum ConvertibleReplies: 0Last Post: 03-06-2007, 12:31 PM -
shaking?
By Fast95Bird in forum General HelpReplies: 1Last Post: 10-08-2005, 01:34 AM
