Thread: Steering shaking
03-10-2010, 06:42 PM #1
Steering shaking
I just installed some rims and had them balanced, but the steering wheel shakes violently once I hit 50 and makes it almost undrivable. The steering wheel goes from left to right very quickly, I can't figure what it could be. Help??
03-10-2010, 06:45 PM #2
- Jan 2010
- New Mexico
- 1999 Chevy Camaro z28
Was in the tire and rim business for a long time and I would say that either you have a bent rim or they did a terrible job balancing those tires!!!
03-10-2010, 06:55 PM #3
It was a friend that did it. Thing is the tires been mounted for over 2 days and its held pressure, drives fine up to 45 MPH, and it also balanced fine, but could a rim be bent? He said the rims all seemed fine so that left alignment on my list of troubleshooting maybe because it only starts after 45 MPH
03-10-2010, 07:00 PM #4
- Jan 2010
- New Mexico
Yes i can almost promise they are not balanced right i would have them rotate them around and if you feel the vibration in your seat then i would say more than likely its going to be a bad balance.
03-10-2010, 07:11 PM #5
Okay thanks man, then i'll go to a shop as much as i'd rather not and just have them balance them again. The steering wheel's also going rapidly left to right, not as much vibrating. I don't know if that info would make a difference in troubleshooting. Seeing how the rim seems fine, should I rule out a rim being bent? Or wait to see how balancing goes? And should I do an alignment while i'm at it? I switched from 16's to 17's if it makes a difference at all
03-11-2010, 11:07 AM #6
- Jan 2010
- New Mexico
I would just wait until they rebalanced them and go from there!!!
03-12-2010, 11:55 AM #7
- May 2009
- Central Florida
red- 2000 Z28
You might want to check for uneven treadwear while you're at it.
03-12-2010, 01:49 PM #8
- Feb 2007
- San Diego, CA
I hope you're spin balancing them.
And are they using taped on or rim mount weights?
I had a wheel weight come off and it did like you're describing.
03-12-2010, 07:50 PM #9
Yeah, they've been spin balanced, my friend did it once and didn't notice its pulling different numbers everytime. They used rim mount weights, which i'm not a fan whatsoever. Plus I found out it's a rim thats bent. Such a slight one that it only shows up after 45 MPH, so now I need 1 ZR1. My life sucks. Thanks for the help guys
my car is shaking
By camaronoob in forum V6Replies: 15Last Post: 07-01-2010, 06:05 PM -
What's shaking
By Golicous in forum New Member IntroductionsReplies: 3Last Post: 05-20-2009, 01:23 AM -
shaking in steering wheel after 55
By ou812 in forum General HelpReplies: 13Last Post: 04-23-2006, 09:53 PM -
steering wheel shaking excessivly
By esoj1987 in forum Suspension and HandlingReplies: 6Last Post: 02-14-2006, 04:44 PM -
shaking?
By Fast95Bird in forum General HelpReplies: 1Last Post: 10-08-2005, 01:34 AM
