01-30-2006, 01:15 PM #1Junior Member
- Dec 2005
- sac
black- 2000 trans am
steering wheel shaking excessivly
hi
my car just came back from the body shop for some minor bodywork done to the door and part of the fender. while in the body shop they had to push the car from stall to stall to complete the repairs.(this car is not easy to push while its off). when i got the car back i replaiced the ignition switch wich was bad. the car runs fine under 40 mph but when you hit 45mph and above the steering wheel starts to shake alot and i mean alot. it did not do this before. i balanced the tires and that helped a little bit, but i still whont take it on the freeway because of this problem. its a 2000 PONTIAC TRANS AM. i know the body shop messed it up, but i whant to know what they did. it ran perfectly fine before the body shop got their hands on it. th body shop obviously dennies they had enything to with that, but i am so gonna sue
01-31-2006, 04:40 PM #2Junior Member
- Jan 2006
- Virginia
white/orange- 97 30th SS
The tires might have flat spots depending how long the car was sitting for, also check the front suspension to make sure all the bolts are tight
02-01-2006, 07:41 PM #3Boy, this is a tough one... did they bend any suspension parts, run it over/into anything? Is the wheel alignment correct? You seem to have eliminated wheel balance as the problem: could they have bent a wheel? Are any suspension parts worn like tie rod ends, wheel bearings, ball joints and they happened to do something which made the symptoms much worse, highlighting an existing problem? It is so hard to tell, but you did the most obvious thing first which was to check the wheel balance. You need to have a good suspension shop look over your front end, it's hard to diagnose a problem like this from a distance. Good luck!
Originally Posted by esoj1987
02-02-2006, 09:25 AM #4Junior Member
- Dec 2005
- sac
thanx
02-10-2006, 04:10 PM #5
Check your alignment. We had a car (wasn't a T/A, I think it was a Crown Vic, but nonetheless another fairly large, RWD car) come into the shop one time doing this exact thing. It turns out someone had not tightened a lot of stuff down properly (not us
) and what had happend was the toe in on one wheel was waaaaaaaaay in and the other was normal. It was actually causing the tire with the crazy toe in to SKIP across the road
. Chewed up the tire pretty bad too, so check for abnormal wear on all four tires, mostly the fronts.
Hope you find the fix.
02-14-2006, 03:29 PM #6Junior Member
- Dec 2005
- sac
FIXED!! it was the tires. thanks 4 vall you help.
02-14-2006, 04:44 PM #7Alcohol Injected
- Nov 2005
- Knoxville,Tn
Black- 1999 Pontiac Firebird
They look like eggs on the balancer???? lol oddly, it usually take a few months to get flat spots on tires, once you heat them up reall good for a hundred miles or so they will be round again, especially if they have a lot of nylon in them....like WR and YR speed rated tires. I am glad it was nothing major. -Tim
Question: steering wheel
By Rmaverickz28 in forum Suspension and HandlingReplies: 7Last Post: 10-28-2010, 09:32 AM -
Steering shaking
By BirdCountry02 in forum Suspension and HandlingReplies: 8Last Post: 03-12-2010, 07:50 PM -
WTB Steering wheel
By enjun in forum Parts Wanted / TradeReplies: 0Last Post: 06-22-2008, 09:17 PM -
Steering wheel LED's
By 02bluez28 in forum Stereo and ElectronicsReplies: 1Last Post: 05-04-2007, 09:39 AM -
shaking in steering wheel after 55
By ou812 in forum General HelpReplies: 13Last Post: 04-23-2006, 09:53 PM
