    Nov 2011
    CT
    Thumbs up Coolant/Brake Fluid Replacement
    '01 Trans Am WS-6
    I'm looking to flush and refill my brake fluid and coolant. It's been 12 years - I think it's time.
    How much of each should I buy to get things back up to normal level after the flush??
    Thanks!!!
    2 Gallons Dexcool Antifreeze
    2 Gallons of Distilled Water
    If your flush the system, let the car warm up to open the t-stat, next carefully open the peacock and drain. Have a hose and let the water flush it all out, may take a few mins. Once your happy with the flush, close of the peacock and ad 50/50 coolant and water. Warm car up and add more if necessary.
    Break fluid - Mity vac is the beast thing you could get to do fluid changes. How much you need can vary. I would have 2-3 bottles on hand. You can always return the unopen ones.
    At 12 years old, I would be replacing the hoses and thermostat. Be sure to pull the block drains to get all the old coolant and trash out.
  1. Brake fluid
    By jroc in forum General Help
    Last Post: 08-11-2008, 11:57 AM
  2. brake fluid sprayed in EYE.. how bad is it?
    By greatwhiteZ28 in forum Almost Anything Goes
    Last Post: 11-18-2007, 04:35 PM
  3. DOT 3 / Dot 4 brake fluid question?
    By davered00ss in forum Suspension and Handling
    Last Post: 08-19-2007, 03:01 PM
  4. Brake Fluid Everywhere!
    By Neil in forum General Help
    Last Post: 09-26-2006, 04:52 PM
  5. Coolant Flush*Fluid?
    By 01JameSS in forum General Help
    Last Post: 10-04-2005, 05:12 AM
