Thread: ngk tr55 spark plug issue
04-11-2013, 02:58 PM #1
So I just puled all my plugs and im wondering what your guys opinions are they have about 8 k on them I just swapped to tr6, s
http://i1197.photobucket.com/albums/...411_181736.jpg
04-11-2013, 03:01 PM #2
Im concerned with the oil on the threads im also running the polluter cam
04-11-2013, 04:13 PM #3Senior Member
- Apr 2010
- Alabama
Have you had a dynotune with the cam? They look burnt to me as well as well oiled. Also have you run any sea foam or something similar through your engine? It has been known to foul plugs.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
04-11-2013, 06:34 PM #4
04-12-2013, 03:51 AM #5
If your engine is burning oil, you will have telltale blue smoke coming out the exhaust. I can't really see the electrodes in the pic, but the coloration really doesn't look too bad. Did you clean around the plugs before removing them? Any external oil weepage from the rocker cover down into the plug wells? If so, the threads will come out with an oily look to them.
FWIW, stop dumping Seafoam into your car. Once a year, use Chevron Techron Fuel System Cleaner and, if you insist on running something else, then do the TCW3 oil treatment at one (1) ounce per five (5) gallons of fuel as often as you would like.
04-12-2013, 04:33 AM #6
Get a catch can if your concerned about oil use.
04-12-2013, 04:54 AM #7
from what I can see they don't look that bad to me....electrodes look like a decent color from what I can tell and that's not enough oil to worry about.
04-12-2013, 05:45 AM #8Former Mopar Man
- Jun 2011
- Branchville, NJ
A very light tan color is normal.
04-12-2013, 07:53 AM #9
I agree, not a good pic of the porcelain but from what I can see the color looks fine. Just a heads up, going to the TR6 is a colder plug so if you are worried about oil or gas fouling the issue would actually be worse with the colder plug.
Any oil entering the combustion chamber is a bad thing, and alot of that can be traced back to the horrible PCV design. I agree these engines all need catch cans, I'd invest in one if you don't have it already just as suggested. That would clean up some of what you are seeing.
Would be hard to see any oil smoke out the tailpipes if you are still running cats (unless you have a very severe oil issue), because the cats burn up most everything before it exits the tailpipe, so mild smoke usually won't make it out the tailpipes.
I also use the TCW3 2 cycle oil mixed in the gas just as Jeff suggested, 1 oz per 5 gallons for gas engines, and I mix 1 oz per 2 gallons for the diesel. Good cleaning and lube abilities at the same time. It's also cheap to do. $11 for a gallon at walmart will treat about 600 gallons at that gasoline mix ratio.Last edited by Firebirdjones; 04-12-2013 at 07:58 AM.
04-12-2013, 11:39 AM #10
The tr6s were recommended by martin over at tick gapped at 45 thats why I switched and I have a catch can already the porcelain lookes good I was concerned with the oil on the threads when I did the cam and spring I put all new head gaskets valve seats and new valve cover gaskets .. and I was told for every 100 hp you go a step colder my baseline was 305 after all my mods I came out to 411 hp with 370 tq
Polluter,410 gears,ls6 intake,pacesetter long tubes ,tsp true duals,slp pulley,slp lid,stock pp throttle body,strano springs n sway bars,founders performance stb,Lca's and Lca relocation brackets,adjustable phb and phb relocation bracket,umi 3point sfc's ,diamond stg2 clutch,koni 4/3s,mgw shifter
04-12-2013, 01:30 PM #11
Is your catch can... catching? Some designs are better than others. Maybe open up your throttle plate a take a look inside with a flashlight to see if things are oiled up.
04-12-2013, 06:03 PM #12
What kind of oil 5w30& spark plugs&spark plug wire
By ROMERO98Z28 in forum General HelpReplies: 20Last Post: 09-01-2009, 01:50 PM -
NGK TR55-IX Iridium Spark Plugs
By LS198Z in forum Parts For Sale / TradeReplies: 0Last Post: 06-18-2006, 03:35 PM -
Spark plug wire and plug!
By RYDER661 in forum General HelpReplies: 2Last Post: 03-13-2006, 09:01 PM -
spark plugs, tr55 iridium or plane tr55 plugs?
By got-a-ls1 in forum General HelpReplies: 8Last Post: 02-09-2006, 06:06 PM
