Results 1 to 20 of 21
Thread: Something strange????
04-03-2013, 10:53 AM #1
- Feb 2013
- Louisiana
red- 2002 35th LE SS
I have a 2002 ss with the t-56 6 speed. Did the skip shift delete with a resistor from radio shack. All of a sudden i get in my car turn the key to the on position depress the clutch pedal and attempt to start the car nothing happens. Gauges and lights on the dash are all normal!?! Bring my truck over and attempt to jump it off.... same thing. get out my meter battery is fine. Beginning to think its the clutch switch if there even is one... So i "rock they key" back and forth. (twist key to on and off position rapidly) BAM it fires right up like it was no big deal. Runs fine but i did notice the security light on the gauge bezel stayed on for a bit, which is not normal. The only reason I am posting this is because it has happened a few times now. what can i bypass or replace to fix this? Thanks for the help.
Tony.
04-03-2013, 11:00 AM #2
VATS is acting up
Read this:
http://www.ls1.com/forums/f6/how-byp...ur-vats-61262/
Still look at the safety switch for the clutch. Just follow the pedal up and you'll see a while cylinder thing that should be touching the pedal shaft. It may be off. They crack and break over time. You do have 2 options to fix this. Replace it or use zip ties to hold it in place. I did the second one, going on 3 yrs now and no issues.Last edited by SMWS6TA; 04-03-2013 at 11:03 AM.
04-03-2013, 11:10 AM #3
- Feb 2013
- Louisiana
Thanks for the help. I really appreciate it.
04-03-2013, 11:11 AM #4
looks like another trip back to radio shack for some more resistors.
That link up there has a ton of info on doing the bypass.
04-03-2013, 11:15 AM #5
- Feb 2013
- Louisiana
04-03-2013, 11:23 AM #6
04-03-2013, 12:09 PM #7
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
04-04-2013, 03:10 PM #8
- Jan 2009
- North Jersey
The more I read about this issue, the more annoyed I become. And I don't even own an F-body.
04-05-2013, 06:39 AM #9
04-05-2013, 06:41 AM #10
04-08-2013, 11:09 AM #11
- Feb 2013
- Louisiana
Ok here is the scoop.... I have a fluke meter and am familiar with its operation and electrical. "Not familiar enough apparently" When I ohm across the chip ("silver part on one side of the key, from end to end") my meter spikes anywhere from 0.8-0.6 ohms. Then quickly works its way down to 0.2-0.1 ohms. It rocks between 0.1 and 0.2. and the meter is beeping indicating a completed circuit... My issue is what freaking resistor do I buy????
Thanks for the help guys.
04-09-2013, 10:36 AM #12
4th Gen LT1 F-body Tech Articles
Based on your readings it looks like you have pelet 3 Low 654 ohms, High 728ohms, nominal 681 ohms.
This chart is for any GM product, Buick, Cadillac, Oldsombile, Chevrolet, and Pontiac that has a VATS key (single or double-sided.)
VATS # (K)OHMS (Set your meter to the 20k ohm setting)
1———— 0.402
2———— 0.523
3———— 0.681
4————-0.887
5————-1.130
6————-1.470
7————-1.870
8————-2.370
9————-3.010
10————3.740
11————4.750
12————6.040
13————7.500
14————9.530
15————11.801
which ever one you are closest too this is the resistor you need. You may need to combine a few to get around the number you need.
04-09-2013, 10:48 AM #13
- Feb 2013
- Louisiana
Ok i see my meter only has 1 ohm setting... thanks so much ill go pick up another meter.
04-09-2013, 10:58 AM #14
- Jul 2009
- North of the Motorcity
No need for a new meter. Your fluke should be auto ranging, you won't have multiple settings for resistance readings.
I believe your measuring it incorrectly. That low of a reading is for continuity, your measuring the key itself I believe. You need to measure the chip it's self.Last edited by KMdef9; 04-09-2013 at 11:03 AM.
04-09-2013, 11:11 AM #15
04-09-2013, 11:15 AM #16
- Jul 2009
Here's what the setup should look like when your measuring the resistance. Careful not to touch ANYTHING else, other than the two little pieces of metal.
04-09-2013, 11:47 AM #17
- Feb 2013
- Louisiana
ok when i ohm like you show in the pictures i get no reading at all.... i was ohming from one end of the silver chip inside the black chip to the other... like it was a barrel fuse. i have a fluke 322 clamp meter
04-09-2013, 11:58 AM #18
- Jul 2009
The 322 is namely for higher load applications, residential, industrial, etc. But should work fine.
I had to wiggle the leads alittle bit to get a reading on my meter. Try that, it should give you a reading after a few seconds sometimes (takes the autorange a few to catch up).
Do you have your other set of keys?
04-09-2013, 12:08 PM #19
- Feb 2013
- Louisiana
yes and i have the same issue with the readings.... i do mostly industrial work... 480v stuff
04-09-2013, 12:56 PM #20
you ohm that pellet from side to side....clean the pellet first with a pencil eraser or even hit it with some scotch brite or something to make sure you're making good contact.
STRANGE,STRANGE Trans Ams
By fbodyNATION in forum Firebird / WS6Replies: 4Last Post: 08-27-2013, 03:29 PM -
Strange
By wooddaniel in forum Manual TransmissionReplies: 8Last Post: 10-16-2009, 12:14 PM -
strange s60
By El Toro Loco in forum DrivetrainReplies: 50Last Post: 11-16-2008, 09:20 PM -
strange s 60
By tomsws6 in forum DrivetrainReplies: 0Last Post: 05-17-2008, 07:51 PM -
strange S60?
By 0verkill in forum DrivetrainReplies: 1Last Post: 12-08-2007, 06:39 AM
