Results 1 to 2 of 2
Thread: strange S60?
12-07-2007, 11:06 PM #1
strange S60?
Im looking at new rearends for my 01 TA m6 and an thinking about the strange s60 thay say its stronger then a 12 bolt and almost as strong a the 9 inch i just want to know if any one has one and how they like it
12-08-2007, 06:39 AM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
I just bought a custom Brand new 9" rear end. I got the Moser case and 35 spline axles. I then added the Strange Pro Nodular case with Motive Performance 4.30 Gears and a Detroit locker. I think Moser has the better case and axles but Strange make a better 3rd member.
Strange makes a Dana 60 for the fbody, They are Ideally the best rear end you can get however, I have researched that the torque arm mount is not that good on the strange housing and the rear end housing is tweaking and causeing gear whine. + you have to do a few more things to get them to fit (shorten the drive line, send in your backing plates to get welded to the axles or purchase new ones), And they have a back order of 4-5 weeks.
Unless you have over 1000 hp which I highly doubt, the moser 9" with 35 spline axles is more than enough. They have been around long enough to prove themselves. I would not recommend a 12 bolt with a 6 speed the 9" has a much better torque arm design and the gears will remain quiet. + the 12 bolt has a 8.75 ring gear and the 9" has a 9" ring gear.2000 SS Camaro Heads, Large cam, Fast 90, 9"w/430's and locker, yada yada yada... you get the picture
STRANGE,STRANGE Trans Ams
By fbodyNATION in forum Firebird / WS6Replies: 4Last Post: 08-27-2013, 03:29 PM -
Strange
By wooddaniel in forum Manual TransmissionReplies: 8Last Post: 10-16-2009, 12:14 PM -
strange s60
By El Toro Loco in forum DrivetrainReplies: 50Last Post: 11-16-2008, 09:20 PM -
strange s 60
By tomsws6 in forum DrivetrainReplies: 0Last Post: 05-17-2008, 07:51 PM -
strange S60
By 02T/AWS6 in forum DrivetrainReplies: 7Last Post: 11-14-2006, 04:32 PM
