    Member Whitefish's Avatar
    Apr 2012
    Central Ohio
    How difficult are front shocks/struts?
    I hear a lot of horror stories about changing them out & it has me a little scared to try it. Anyone know of any write-ups? I searched & couldn't really find one. Thanks.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    They are not too bad to do. The fronts are harder than the rears. I you are not sure you can do the job then have a professional help you with the job or just do it for you. You can get hurt taking the springs off.
    Apr 2012
    Central Ohio
    I called the shop & they want $360 just to swap out the fronts & do an alignment. I think it is worth a try to do it myself for that much money. I will definitely get a spring compressor.
    phoenix
    04 2500 4x4 crew cab
    You should replace the ball joints while you have it apart. ANd, you will have to have an alignment done when you are done.
    Member chris1974's Avatar
    Jan 2012
    Houston
    Bright Red
    1998 Firebird Formula LS1
    Good thread. I'd be interested in a write up too. I'll search a later when I get off work...if I find one, I'll throw up a link.
    Member ZForce1's Avatar
    Maine
    1999 camaro Z28
    There is a good write-up for front/rear shock swaps on LS1howto.com
    I have pulled mine out and reinstalled them while changing out the K-member -- not bad at all to do. Mine will be coming out again for installation of the Konis I purchased from Keith.
    Give me a place to stand. levityinc3's Avatar
    Jacksonville, FL
    2000 SS '89 IROC-Z
    Fronts are a pain in the ass. You should get new strut mounts for the fronts, the old ones are usually so rusted out that you can't get them off. I recommend Moog.
  1. Wanted: WTB front shocks/struts
    By Blackbird WS6 in forum Parts Wanted / Trade
    Last Post: 06-28-2011, 08:15 PM
  2. Shocks or struts?
    By jeffsredt/a in forum Firebird / WS6
    Last Post: 07-21-2009, 04:40 PM
  3. Adj. Front And Rear Struts/shocks For 02 T/a
    By RAMAIR02 in forum Parts Wanted / Trade
    Last Post: 08-04-2008, 05:18 AM
  4. Front Struts/ Rear Shocks?
    By ssxcytmnt in forum General Help
    Last Post: 11-11-2007, 08:35 PM
  5. Best shocks/struts
    By Mr. Luos in forum Suspension and Handling
    Last Post: 08-20-2006, 08:01 PM
