Results 1 to 20 of 34
Thread: Best shocks/struts
07-21-2006, 02:15 PM #1Slow'er'Ass
- Thornton, CO
Best shocks/struts
To use with the Eibach ProKit???
Gets some drag track time, but mostly street.
Actually, for that matter...what struts/shocks fit with those springs period?
07-23-2006, 03:36 PM #2Junior Member
- Mar 2006
- Cleveland Ohio
Pewter- 99 TransAm
Koni SA's, revalved Bilsteins both work well with the Eibach's. I ran option 2 for 4 years , loved it.
99' T/A M6
433hp 405tq
12.41 @119 on a 2.14 60'
http://www.geocities.com/viper99ta@s...?1151262200545
07-24-2006, 07:44 AM #3Slow'er'Ass
- Thornton, CO
What about KYB AGX??
07-24-2006, 01:44 PM #4Junior Member
- Mar 2006
- Cleveland Ohio
Pewter- 99 TransAm
No experience personally with them, but Sam Strano has said for years they are not enough to handle the Eibach's.
07-24-2006, 08:50 PM #5Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
they're made for the stock springs, but are just a cheap and minor upgrade to stock. Revalved bilsteins or Koni's as mentioned. Id suggest the DA's since they're adjustable in car. If you go with the revalved they're gonna be valved for those spring rates, so if you decide to change springs, your probably gonna have to do shocks/struts also. the adjustable koni's are worth the money IMO. I went with bilstein HDs since they suit my needs and my budget at the time.
07-24-2006, 08:52 PM #6
I had the KYB AGX's on my eclipse. Car sat uneven. Redid them... swapped sides and still didnt sit evenly. I may have adusted them twice in 6 yrs. Sooo I swapped them out with some tokicos I believe and the car sat fine. I wouldnt get adjustables again.
07-24-2006, 08:52 PM #7Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Check out one of our sponsors
http://www.ls1.com/forums/showthread.php?t=22868
07-24-2006, 10:08 PM #8M6 King
- Mar 2006
- WI
- Blog Entries
- 1
I have the AGX's and pro-kit now and they work fine and are more than enough to handle the pro-kit. I havn't had the time to mess with differnt settings much yet. I'd go for Koni SA's if I did it again.
07-25-2006, 05:45 PM #9Slow'er'Ass
- Thornton, CO
Well I ordered the AGX for the rears...gonna see how that works for now.
Ordered before I saw the responses.
Guess I find out now.
07-29-2006, 11:24 AM #10Detailing + Design
- Pittsburgh, PA
Luos, for as much money that you put in that engine, you'll want double adjustables. I think Qa1's will work for you
07-31-2006, 08:28 AM #11The Mudkat
- Jun 2006
- "The good Lord sez he can get me outta this, but he sez he's pretty sure you're *****d!"
white- 2000 SS Convertible
Koni SA's...just awesome. DA's only needed if you're goin road racin.
08-01-2006, 01:04 PM #12Crazy Canuck !
- Jun 2002
- Montreal, CANADA
Eugenio_SS
08-01-2006, 01:58 PM #13Slow'er'Ass
- Thornton, CO
Okay...should I try out the KYB AGX??
Or just go with a revalved Bilstein and try to get a good amount of my $$ back for the KYB's?
I don't have a lot to spend right now.
08-02-2006, 03:44 AM #14
08-06-2006, 12:37 PM #15maroonZGuest
I just bought Koni DA from SLP on Thursday for $700 for complete set. They were trying to clear them out.
There should have been 2 sets left in stock.
I have them installed in a couple of weeks
08-06-2006, 12:42 PM #16Slow'er'Ass
- Thornton, CO
I just can't afford that.
Revalved Bilsteins seems like the best route for me.
08-09-2006, 07:19 PM #17Senior Member
- Aug 2003
- Honolulu HI
they are..go with them...at the least.
08-13-2006, 02:42 AM #18Member
- South of Heaven
Navy Blue Metallic (NBM)- 2002 Camaro SS
Koni's are the best, followed by revalved Bilsteins...
KYB is just an acronym for Keeps You Bouncing!
08-15-2006, 01:45 PM #19
08-20-2006, 09:34 AM #20Member
- Buffalo
IMO you don't need a shock that really resists a lot of movement unless you slam the car way low and its constantly bouncing. A 1" drop won't create a lot of bounce. I have factory SS shocks on the rear of my car, and it is has the eibach 1" to 1.5" drop kit. I dont remember how much drop I have now. And there is ZERO bounce in the rear. The front I have installed bilstein because there is more weight up there to control. However, I would avoid buying "Monroe heavy duty". Those are not heavy duty enough for an extreme drop. I know because I tried it. haha Its like the shock would not respond fast enough to the spring action. So if you want to save some money, just get some cheaper shocks for the rear and something more heavy duty for the front.
If you really want to elminate a lot of lean in the car when cornering, get a 35mm front anti-sway bar and the matching rear anti-sway bar. I removed my factory ones and oh my gosh! soooo much better. Drastic sotp difference.
Question: what shocks and struts to use??
By timothyodell2525 in forum Suspension and HandlingReplies: 16Last Post: 09-29-2011, 07:40 AM -
Do we have shocks or struts?
By Street Fighter in forum General HelpReplies: 23Last Post: 08-14-2011, 07:26 PM -
Shocks or struts?
By jeffsredt/a in forum Firebird / WS6Replies: 8Last Post: 07-21-2009, 04:40 PM -
What shocks/struts?
By JwMonE99 in forum Suspension and HandlingReplies: 2Last Post: 06-25-2009, 07:59 PM -
Shocks\struts Best Buy??
By natess in forum Suspension and HandlingReplies: 2Last Post: 12-17-2005, 02:48 PM
