Results 1 to 20 of 20
    Member Thewilldog's Avatar
    Jacksonville, FL
    2001 Z28
    Gotta replace Water Pump; clean the Throttle Body too?
    Hello,
    Just got the news that my coolant leak is coming from the water pump on my 2001 Z28. The car has 177K miles, so it's probably a fair time for replacement. The shop quoted me a repair cost of $575. I think I can do it myself for less although I've not attempted the repair previously.
    I found this thread that contains a detailed write up of how to replace the pump:
    http://www.ls1.com/forums/f63/water-...nstall-110724/
    I see that I've gotta remove the throttle body to get at the pump. I suppose that I may as well clean it while I have it removed. There are an number of threads that delve into sprays used to clean the TB, such as:
    http://www.ls1.com/forums/f6/throttl...cleaner-88761/
    However, I don't see any corresponding guides on how exactly I'm supposed to clean the part. Is it similar to cleaning brake calipers where you just spray down all the surfaces inside and out with cleaner and let it drip dry and/or wipe away excess with a paper towel? Or is there more to it than that? I ask because I've never worked with the thottle body before.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I spray throttlebody cleaner on a clean rag then clean the throttlebody with the blade open to get all the carbon/gunk out.
    As for the water pump, I think there are members who have replaced theirs without removing the tb. They just moved the radiator out of the way. I could be wrong.
    In regards to the tb, if you are going to soak it down remove the trottle position & IAC sensors. Those chemicals can effect the sensors. Now when you pull it off and get a look at the back side you'll see what needs to be cleaned, it will be covered in oil residue. I used some Q-tips to get the outlet that directs air into the valve cover. Carb cleaner is what I use.
    Water pump - Removing the TB just makes it easier to work on the water pump.
    Greensboro, NC
    2002 Trans Am WS6 M6
    Replacing the water pump is easy. One of the first engine related things I ever did to my car.
    Jacksonville, FL
    2001 Z28
    The internet is telling me that either one of these pumps will fit the car:
    ACDelco 252-846 Water Pump
    Bosch 99175 Water Pump
    and that I should get this gasket along with it:
    Fel-Pro 35635 Water Pump Gasket
    Can anyone who has replaced the pump using one of the above confirm that everything worked out?
    Member robs98mysticZ's Avatar
    Mar 2011
    Waynesboro, Pa
    Mystic Teal Metallic:320c
    1998 Camaro Z/28
    i got an acdelco when i replaced mine works great and about the gaskets go to dealership for the metal gaskets there cheap and can be reused if wanted you will need two gaskets they are metal and rubber great pieces
    ive used gm gaskets with everything and seems there better and will last longer imo
    North Jersey
    2004 GTO M6
    When I replaced the water pump on an 02 Suburban, the pump came with the metal/aluminum gaskets. Better than cork.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Both jobs are very easy. 525.00 is way out of line. You can do both with a few basic hand tools and a few hours of time.
    Jacksonville, FL
    2001 Z28
    Quote Originally Posted by robs98mysticZ View Post
    I don't understand this response. Why would I need two gaskets? Is this the right one?
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Quote Originally Posted by Thewilldog View Post
    One for each side of the pump.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Junior Member psycho_puppies's Avatar
    Jul 2009
    New Mexico
    2002 TA
    Thse are picts of the gaskets and where you attach the h20 pump to the motor. You don't need to take the TB off. I did the job in about 2 hours but I was being slow.
    Mar 2011
    Waynesboro, Pa
    1998 Camaro Z/28
    it takes longer to drain the coolant than anything, you need a flat head for the intake couplers, then a 10mm for the 6 bolts and pliers for the hoses, and a 15 or 16mm for your belt tensioner... you will also need to swap your tstat housing onto your new waterpump, when you put the new waterpump on put 3 bolts in partway to hold the gasket on one side, get the bolts started then slip the new gasket in on the other side using the bolts to make sure everything is lined up.
    - - - Updated - - -
    make sure you clean/scrape any old gasket residue off the front of the block as well
    Jacksonville, FL
    2001 Z28
    - - - Updated - - -
    Curious, what did you do with the old coolant, kill weeds?
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    Put it in a well sealed container and bring it to Autozone or O'Rielly's ... they'll take it off your hands for free. Don't dump it, a lot of coolant is toxic to animals and that just makes for a bad day.
    This....I didn't know I had a coolant leak, one morning I found my neighbors cat its guts out next to my truck. As I pulled out of the drive way I saw the puddle and made the connection. Cat lived but doesn't come over to my house any more, so win, win....
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I found a dead cat back behind my garage once. Few days later I found out my neighbor put out anti-freeze for the raccoons because they kept getting into his garbage cans. Wasn't fun cleaning that up. Even though I don't like cats, I was
    Jacksonville, FL
    2001 Z28
    - - - Updated - - -
    Success! Took most of the afternoon, but I was able to swap the water pump with a new one as well as clean out the throttle body with some carb & choke cleaner. I also replaced the thermostat and housing.
    I actually had to remove two of the belt pulleys; the tension pulley and the pulley directly in front of the bottom right hand screw holding the pump in place. It was blocking my socket wrench. You were right, it did take a while to drain the coolant.
    Just got back from a test drive and didn't find any leaks and didn't over heat, so I think I'm good to go.
    Mar 2011
    Waynesboro, Pa
    1998 Camaro Z/28
    sorry i didnt respond when i did mine i had fresh coolant from my cam swap...if only the pump went prior to the swap lol....i drained mine into a CLEAN container and filtered it prior to reusing it. glad all went well for you!
    Jacksonville, FL
    2001 Z28
    Only caveat, I didn't think the pump would come with the corresponding gaskets (it did) and I didn't realize they were sold in pairs (they are) so I now have two sets of gaskets I don't need and will probably never use. Oh well, good learning experience.
    North Jersey
    2004 GTO M6
    When I changed the water pump on an 02 Suburban a few years ago, I had fun.
  1. Question: How "deep" is the Throttle Body water jacket?
    By GatorSS in forum External Engine
    Last Post: 10-19-2009, 04:01 PM
  2. Replace Clean Firebird with Salvage Bird?
    By clovenhooves in forum Firebird / WS6
    Last Post: 08-19-2009, 09:19 PM
  3. How do I clean the Throttle Body and Air-intake ?
    By Speedy_Gonzales in forum External Engine
    Last Post: 03-21-2008, 10:06 PM
  4. Do electric water pumps pump enough water for daily use?
    By xinthenight in forum External Engine
    Last Post: 08-02-2007, 10:04 PM
  5. Anyone Replace their Power Steering Pump?
    By Neil in forum General Help
    Last Post: 05-18-2006, 10:35 PM
