Thread: Brakes
12-28-2012, 04:36 PM #1
Brakes
I was thinking about me brake and was wonder if anyone have put vette brakes on their car. If so can you tell me what vette brakes you used, plus was it worth it, about how hard was it to do, and what is needed to do a full swap? My car is a 01 camaro ss
2001 Camaro SS, LM 1, BMR LCA, relocation brackets, BMR springs, adj panhard bar, smooth below, lid, sub-frame connectors weld on, strut brace
2000 WS6, ls6 intake, sub-frame connectors, slp maf, slp cat delete with slp y-pipe, electric cutout, strut brace, smooth below, slp lid, bmr LCA and RLB
12-28-2012, 04:56 PM #2
- Jun 2011
- Branchville, NJ
I think the 2001-02 Camaro SS had the same brakes as the same year Vette. I think but I'm not sure.
12-28-2012, 06:59 PM #3
- Apr 2010
- Alabama
I swapped out my brakes for CTS-V 4 piston brembo calipers and c6 z06 14" rotors. If you don't want to do something like this a simple swap of rotors and brake pads for better ones will do as well. Here is a list of what I needed:
CTS-V Calipers
Caliper pins
CTS-V brake pads
14" Z06 rotors
Wheel spacer
18+" wheels
4 M12 washers
Custom Brake lines from flynbye.com
The total cost was between $600-800 dollars not including wheels, which I already had.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
12-30-2012, 08:18 AM #4
- Jul 2009
- North of the Motorcity
Some places make a C5 conversion kit, and as long as your comfortable bleeding brakes, you should be fine.
I'll PM you the links.
12-31-2012, 07:45 AM #5
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I also have looked at the C5 conversion kit pretty straight forward, UMI offers them just be sure to read what wheels will NOT work with the conversion. My wheels won't, others went with r1 concepts rotors and pads with braided lines , much improved over stock, that is the direction I'm headed
12-31-2012, 08:10 AM #6
Brakes - Road Racing Brakes
By Intrepidman in forum General HelpReplies: 6Last Post: 03-30-2010, 08:49 PM -
Question: Brakes! I need'em. What do you use on your car??
By Hi-Po in forum General HelpReplies: 21Last Post: 07-07-2008, 06:49 PM -
1966 El Camino Brakes - Brakes In a Box
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 06-06-2008, 10:10 AM -
c6 zo6 brakes on a c5
By NIKDSC5 in forum CorvetteReplies: 9Last Post: 09-14-2007, 05:35 PM -
need brakes!
By jbb6811 in forum Camaro / SSReplies: 7Last Post: 02-13-2007, 03:30 PM
