    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    Oil Change light still on...
    Only had this car for about 2 months and I got the oil Changed and the Light still won't go away... whats up and how do i get this annoying thing off!
    Thanks!
    Senior Member
    Jacksonville, FL
    It has to be reset. Turn key to RUN, depress and hold the oil/trip reset button on the dash for a few seconds until it goes off - or turn key on, depress the gas pedal 3 times if you want to keep your trip mileage. Should be off next time you start the car. I don't use the GM oil life system to tell me when to change the oil - mine comes on long after it should IMO. Welcome to the board.
    Gulfport
    2000 trans am ws6
    turn the key on like if u just want to listen to the radio or have the a-c on dont crank the car. and push the odometer trip button on the dash for like 10-15 seconds and it should go off.
    Puyallup
    Thanks guys!
    Bragg NC
    Met. Sunset Orange
    01 SS
    I'v got an 01 ss and the dealer told me to turn the ignition to run and depress the gas three times then turn it off then back to run then off again and then start it and it went away.
    J
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Quote Originally Posted by 2000SuperSportMaro
    ...and I got the oil Changed and the Light still won't go away...
    What? You don't change it yourself? Don't tell us that you had it done at one of those "quickie" oil change shops.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    We get alot of customers who think this light resets itself when the oil is changed-if the light comes on they think we didn't change their oil! It's a good system IMHO and I follow it. It changes according to how the vehicle is driven. I recently got a different job that is much closer to home,and so less fully warmed up driving, so it wanted it changed much sooner. Anyway with these cars you can do either the gas pedal or the button on the dash,they both work the same.
  1. Change oil light?
    By 02blckws6 in forum General Help
    Last Post: 11-30-2010, 03:03 PM
  2. change oil light???
    By FRISCO SS in forum Camaro / SS
    Last Post: 02-01-2010, 04:18 PM
  3. Change oil light 02 WS6
    By ccasper69 in forum General Help
    Last Post: 06-14-2008, 12:06 PM
  4. Oil change light then SES light came on. Are they related?
    By third_shift|studios in forum General Help
    Last Post: 08-15-2006, 11:51 PM
  5. change oil light?
    By TA-LVR in forum Stereo and Electronics
    Last Post: 02-21-2006, 08:44 AM
