Results 1 to 15 of 15
04-09-2006, 03:23 PM #1Import Killer
- Sep 2005
- MIchigan
Navy Blue Metallic- 2000 Camaro SS
headers,ORY,Bumpstop and still hitting floor?
ok i've read alot of the threads on here and did as most of you said when i jsut put my pacesetter LT's and ORY on i bought the mufflex bump stop.....Exhaust still hits floor and triggers knock sensor....any ideas??....
04-09-2006, 04:04 PM #2
Take it to a local exhaust shop and have them heat up the pipe and bend it down a lil bit, Thats what i had to do and it's work great so far.
How do you know its triggering your knock sensor?
04-09-2006, 05:43 PM #3Junior Member
- maryland
red- 98 camaro z28 m6
new poly motor mounts
04-09-2006, 05:48 PM #4
I have heard alot of people say motor mounts and tranny mounts but i dunno
04-10-2006, 02:29 PM #5Madeche Vision...soon
- Feb 2006
- Galveston, TX
NBM- '98 Ram Air Formula
I am thinking about getting the bump stop but I need to know where the thing attaches to the car. Is it to one of the subframe runners or do you just screw it through the floor board? Also, let us know when you find a solution to the problem. I just put kooks lt with ory and have a problem with the y-pipe hitting the medial subframe runner.
04-10-2006, 05:46 PM #6Import Killer
- Sep 2005
- MIchigan
the bumpstop goes on a stud that holds the heat shield on the bottom of you rfloor it's a 10mm nut you take off right uner the drivers seat/floor area...very easy to install........I know it's triggering my knock sensor because it will sound like the rev limiter is going but i'am only at 3-4500 rpm's....
04-11-2006, 03:32 PM #7Member
- Jul 2005
- commerce twp michigan
Having kooks headers and off road pipe installed now (car at shop now)
Guy at the shop said y-pipe is hitting also. He said he will add 3" flex pipe
3 places on y-pipe. ? Any body else here this.
04-11-2006, 04:45 PM #8
I dunno about all that but when my ory was banging i took it too local exhaust shop and he heated it up under the ds floorboard and bent it down a lil bit and it went away. I mean iv heard it all as far as people going with new tranny mounts, motor mounts, bump stop hanger but all it took was about ten mins and a guy with a torch.
just my op. thou
J
04-11-2006, 05:18 PM #9Junior Member
- WA
BLACK- 1999 T/A FIREHAWK
I had the same problem until last weekend, I broke loose all the hardware that hold the entire system(except header/head bolts) and removed the bumpstop. Then I got a 2x4 piece of wood and wedge it between the y-pipe and floorboard. Finally I thighten all the bolts and installed the bumpstop and it took car of the y-pipe.
GOOD LUCK!!! IT WORKED FOR ME....
04-11-2006, 07:09 PM #10I Love My Bong
- Sep 2005
- Hot Springs, AR
Midnight Blue- 99' Trans Am
Try removing the heat sheid where y-pipe hits.
04-12-2006, 02:17 AM #11
2x4 Now thats creative, lol but if it works it works
goodshit bud
J
04-19-2006, 02:13 PM #12Import Killer
- Sep 2005
- MIchigan
got it fixed!!!!!! i jsut took the mufflex bump stop off the location they say to mount it (on a heat shield stud) and drilled a hole directly over the exhaust and re-mounted it....works great!
04-19-2006, 06:18 PM #13member since may 2000
- Dec 2002
- n/w chicago
above is what i did and no more banging.
a few bolt ons, 379 rwhp
11.96 @113.25
05-29-2006, 12:08 PM #14
what size bumpstop did yall use? thunderracing has 2.5 and 3inch for sale i have pacesetter lt and ory which one should i go with?
also im guessin the band clamp size is 3 inch also right?
thanks
J
05-29-2006, 04:53 PM #15Import Killer
- Sep 2005
- MIchigan
i'am using the same set up as you and i used the 3"
Kook headers hitting 3 spots rattle and shake
By Durango in forum General HelpReplies: 5Last Post: 04-28-2012, 02:15 PM -
Wanted: Y-Pipe bumpstop hanger
By firemandan1700 in forum Parts Wanted / TradeReplies: 0Last Post: 05-15-2010, 06:16 PM -
Help: Problem with steering arm hitting my headers
By Quick_burk_GTO in forum GTOReplies: 13Last Post: 01-15-2009, 02:13 AM -
bumpstop/sportlines
By sd1971 in forum Suspension and HandlingReplies: 3Last Post: 07-21-2006, 09:47 AM -
TB bumpstop mod questions
By Mark01WS6 in forum General HelpReplies: 5Last Post: 06-19-2006, 02:37 PM
