    BLKHWK Durango's Avatar
    New Brunswick Canada
    BLK TA modded 12.2@113mph
    Kook headers hitting 3 spots rattle and shake
    Well I have a 2000 Trans AM with Kook headers I bought these because they said it would fit perfect Yeah right! It hits on the motor mont drivers side and frame drivers side really bad also on the frame passenger side. On the drivers side we actually cut 1/4 inch in the frame and it still hits any tricks. My buddy has pacesetters and they have tons of clearance he paid 299 for the cheap black ones and I paid 1299 and I get a car that shakes with a lot of noise they are the 1/7/8th to 3" . My muffler guy is really good he says he doesn't want to heat it up any more because stainless might just crumble over the heat I am just about to sell these and buy Pacesetters or just go to stock manifolds but I have a cam and LS6 intake it will kill my set up I think!!!!
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Did you check the headers thoroughly to make sure the primaries/collectors aren't bent?
    How are your motor mounts? Are any of them worn or broken? Also check your transmission mount. Sounds like something is giving way and allowing the engine to move more than it should.
    North Jersey
    2004 GTO M6
    Also, what type of Y-pipe are you running? You might also have to adjust that.
    Coral Springs, Fl
    Sunset Orange Metalic
    Agreed, did you do motor mounts at the same time or at least inspect them?
    My old Kooks did hit the kmember when i was installing them so i had to grind it down a bit.
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    First if I paid $1299 for a set of headers I would be ripping them back off and on the phone with Kooks for a return, thay should fit and not hit anything that is why you spent top dollar for quality product.. Maybe someone was having a bad day at kooks when thay were built and something was off when welded..my $500 pair fit great not even close to hitting
    North Jersey
    2004 GTO M6
    Or maybe they were dropped in transport?
  1. Finally did it EPS222/226 Kook headers dynoed at 360rwhp
    By Durango in forum Internal Engine
    Last Post: 05-04-2012, 09:49 AM
  2. Replies: 4
    Last Post: 04-14-2012, 06:19 AM
  3. T-Top vs Coupe Rattle / Shake ?
    By kool-aide in forum Suspension and Handling
    Last Post: 10-17-2007, 06:26 PM
  4. SLP exhaust, KOOK headers, LS6 heads, RIMS, Motor for lights
    By TransAmDemon06 in forum Parts Wanted / Trade
    Last Post: 07-10-2007, 03:59 PM
