Results 1 to 13 of 13
    Member devildogws6's Avatar
    Monticello MN
    2000 trans am ws6
    what kind of tq arm is this?
    Was on car when I bought it
    Attached Thumbnails Attached Thumbnails IMG_20121121_143412.jpg   IMG_20121121_143428.jpg   IMG_20121121_143357.jpg
    Owning a 9 sec ricer is like coming out of the closest: at first you'll surprise everyone, but in the end you're still gay
    Monticello MN
    2000 trans am ws6
    Nobody knows what tq arm this is?
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    I know it is an aftermarket adjustable unit. Also, your pinion seal is leaking. Check your rear fluid level this weekend.
    Monticello MN
    2000 trans am ws6
    Quote Originally Posted by 2002ssslp View Post
    will do!!!! thank you i will next time i get out to start the car she is currently in storage!!
    I don't recognize it.
    And, FWIW, a leaky pinion seal was a factory installed option on our cars.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    That torque arm looks very similar to a Global West Trac Link.
    Monticello MN
    2000 trans am ws6
    would you stay with it or go dif route, i gotta run though and check everything right now shes got lotta clunking going on under normal driving, not hard acceleration, so idk
    Start by checking your transmission and torque arm mounts, then inspect your suspension bolts to ensure that everything is tight. If that all looks good, take a peek at your sway bar end links.
    Monticello MN
    2000 trans am ws6
    i will do that thanks!!
    99 WS.6 - Modified
    Quote Originally Posted by devildogws6 View Post
    I run the Trac Link on my car, and am happy with it. Just do as Jeff suggested, and you should be good.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    It is not a BMR unit that's for sure.
    SteveC
    Marylandistan
    2001 Trans Am (sold)
    Is that a frame mounted torque arm or a tranny mounted torque arm? Most all frame mounted ones make some clunking. Of it's frame mounted and it bothers you, get a tranny mounted one.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Quote Originally Posted by INMY01TA View Post
    It looks like it's bolted to the tunnel on the top side.
  1. What kind of gas for the LS1
    By vindicator in forum General Help
    Last Post: 03-21-2011, 04:36 PM
  2. Question: what kind of hp's from a le cam will i get?
    By stunna p in forum Internal Engine
    Last Post: 12-07-2009, 02:57 PM
  3. Question: What Kind of Wax do you use?
    By Mustang Killa in forum Showcar and Detailing
    Last Post: 04-20-2008, 07:01 PM
  4. What kind of day did you have???
    By dafizzman1 in forum Almost Anything Goes
    Last Post: 10-21-2007, 05:47 PM
  5. What kind of car are you?
    By BIGRED Z in forum Almost Anything Goes
    Last Post: 04-20-2006, 05:12 PM
