Results 1 to 11 of 11
Thread: What kind of gas for the LS1
02-27-2011, 02:26 PM #1Junior Member
- Feb 2011
- Prague
- 1999 Trans Am
Hi, I just bought a 1999 Trans Am with the LS1. Problem is that when I was in the States, I would put premium, supposedly best 93 octane in my 1997 Trans Am. Now here in Europe, they have 95, 98 and 99 octane gas. Do you guys know the conversions or can I put the 99 octane gas in it without it getting any damage? Thanks
02-27-2011, 05:49 PM #2Senior Member
- Jan 2010
- texas
silver- 2000 formula
i always use regular unleaded in mine.......cant afford that premium
02-27-2011, 05:53 PM #3
Are the European standards for rating octane the same as in the States? If so, you would be best sticking as close to 93 octane as you can. There is absolutely no performance benefit in running a higher octane fuel. In fact, there may be a slight loss of performance. Higher octane only results in more power when the spark advance is adjusted accordingly. Our cars come with a high and low octane spark table -- but it assumes an octane of 91-93 for "high test" fuel.
03-06-2011, 08:37 AM #4Junior Member
- Feb 2011
- Prague
- 1999 Trans Am
03-06-2011, 09:23 AM #5None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Run the 95. Your car should perform fine. As Jeff said, there's no reason to run a higher octane. I have run 94 in mine without a problem.
03-06-2011, 09:33 AM #6
I know you guys in Europe get a different owners manual than we do here in the states. It should be listed in there what is recommended if you have it. I'll ask around Monday and see if I can't get an answer.
03-06-2011, 11:59 AM #7Electrical Engineer
- Jul 2009
- North of the Motorcity
I got significantly worse gas mileage in other vehicles. And it's only $3 more a fill up here for premium as well, so it made for less stops at the gas stations.
The 95 should be fine, not much difference between that and the 93. The 99 I think would have the effect Jeff mentioned.
03-21-2011, 09:47 AM #8Junior Member
- Feb 2011
- Prague
- 1999 Trans Am
Well I had a Suzuki GSX-R 750 bike and that thing was sooo much faster with the 99 octane fuel - it would do 170mph easy, whereas with the 95 octane, it would have trouble hitting 160mph... But I guess I will just try and see if there is a difference in the TA, since you guys say it should not damage the engine
03-21-2011, 09:50 AM #9
03-21-2011, 10:03 AM #10
The higher the octane you run the higher timing your car can run. That is why more octane means more power.. if you have a way to tune it.
03-21-2011, 04:36 PM #1111 years of bangin gears
- Jan 2009
- North Jersey
I run 93 in mine. Even with the stock replacement motor now.
what kind of tq arm is this?
By devildogws6 in forum Suspension and HandlingReplies: 12Last Post: 01-28-2013, 07:01 AM -
Question: what kind of hp's from a le cam will i get?
By stunna p in forum Internal EngineReplies: 3Last Post: 12-07-2009, 02:57 PM -
Question: What Kind of Wax do you use?
By Mustang Killa in forum Showcar and DetailingReplies: 110Last Post: 04-20-2008, 07:01 PM -
What kind of day did you have???
By dafizzman1 in forum Almost Anything GoesReplies: 23Last Post: 10-21-2007, 05:47 PM -
What kind of car are you?
By BIGRED Z in forum Almost Anything GoesReplies: 34Last Post: 04-20-2006, 05:12 PM
