    Junior Member askkmb's Avatar
    May 2012
    Mexiko
    2003 Silverado SS
    head gasket choice
    Hi, i have a new set of gaskets im not using so i was thinking if i could use them in my lq9 build. They are for an 4.030 bore but my lq9 still has the stock 4.000 bore so im thinking if i would lose any compression by that?
    Thanks.
    May 2012
    Mexiko
    2003 Silverado SS
    Anyone please?
    Coral Springs, Fl
    Sunset Orange Metalic
    They would probably work fine but if it was me i'd pick up the right size gasket to be on the safe side.
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Quote Originally Posted by askkmb View Post
    Thanks.
    Can you help me understand what gasket you have? A stock 6.0 liter gasket is 4.030 so if your gasket is that size your just running the oem size gasket.... If your gasket however was made for a 4.030 bore then the gasket may be 4.060 in which case you cannot run it.
    May 2012
    Mexiko
    2003 Silverado SS
    I dont know about the gaskets but the block has a 4.000 bore. And my new set of gaskets are 4.030 so i wasnt sure what size to use since i dont know what the oem size is. But if a 6.0 uses 4.030 size gasket i guess i'm good with my new gaskets, right?
    Mar 2009
    as long as the gaskets measure 4.030 your fine
    May 2012
    Mexiko
    2003 Silverado SS
    Okay cool thank you everyone!
  1. Head/Cam Choice for LQ9 SS Pickup
    By krexken in forum Internal Engine
    Last Post: 09-07-2012, 06:51 PM
  2. STS blown head gasket?? What head gasket
    By 2000sts in forum Forced Induction
    Last Post: 08-26-2009, 02:23 PM
  3. Replies: 4
    Last Post: 11-13-2007, 08:58 PM
  4. New SS owner needs help on Head/Intake choice
    By quickgt in forum Internal Engine
    Last Post: 01-19-2007, 07:44 PM
  5. ARP head bolts, are they a good choice?
    By mvvette97 in forum General Help
    Last Post: 01-17-2007, 06:00 AM
