Results 1 to 14 of 14
    Member mvvette97's Avatar
    leon iowa
    1997 corvette 00 WS6 TA
    ARP head bolts, are they a good choice?
    I was told that they are the best but yet I read that people have had them break. I'm going to be putting my heads on in the morning and have the ARP bolts. How many have had them break?
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I use their studs. They are great. I would have to think the bolts are just as good.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Retired Outlaw Sum Bitch
    If properly torqued they are the best out there. Bar none.
    This is my signature. It is mine. Nobody else has one like it.
    I have ARP head bolts, great product, you won't regret using them.
    Painted manta stripe
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i use the bolts here as well.
    Why wouldn't you guys use the stud kit? Just curious why you went with bolts and not studs. Price?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    The studs have a much greater clamping force thats why you'll 85% of race motors will be studed.
    And ARP is the MOST used bolt on the market in the race seen. If you broke their bolt you have other major issues or your just should'nt be working on your shit anyways!!!!
    We build 80% race motors out of the machine shop and I've NEVER broke one or seen anyone else break one in 5 years. Now we have had some dumbass customers come back with broken bolts. When they tell you to oil the threads that does NOT mean enough to hyd. lock the bolt in the thread.
    You must clean and run chasers through threads prior to assembly.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Just curious. If you use the studs and the engine is in the car, will you be able to fit the cylinder head over the studs?
    Aug 1999
    No Where
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    The only issue we run into with studs is depending on who's headers your running.............. The flange hits the top of the studs stoping the header from properly lining up. Nothing a little grinding won't fix though.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by LS2Tuner View Post
    So you grind the header flange a little so it will seat properly?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yes you grind some on the flanges. It's very easy if you have access to a motor out of a vehical. Just line up the header and mark the flanges where the bolt heads are and grind a 3/8" U upside down.
    Any brands in particular you see this problem with more than others? The reason I ask is at some point this spring I'm hoping to do my heads/cam and was planning on using ARP studs when I did it. I run pacesetter headers and really don't have much of a problem grinding them down but I'm hoping I won't have to do that.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    If you look at the front cylinders you can see look at the amount of clearence you now have from the flange versus the bolt head. If it's close I'de say your going to have issues. The stud is going to be 3'8"-1/2" taller than your bolt head now.
  1. Question: head gasket choice
    By askkmb in forum Internal Engine
    Last Post: 10-16-2012, 07:20 PM
  2. Head/Cam Choice for LQ9 SS Pickup
    By krexken in forum Internal Engine
    Last Post: 09-07-2012, 06:51 PM
  3. LS1 head bolts
    By dar54car in forum Internal Engine
    Last Post: 10-17-2007, 07:54 AM
  4. New SS owner needs help on Head/Intake choice
    By quickgt in forum Internal Engine
    Last Post: 01-19-2007, 07:44 PM
  5. f/s AFR 205cc, head gaskets, and head bolts
    By slimeball6969 in forum Parts For Sale / Trade
    Last Post: 08-12-2005, 09:17 PM
