09-24-2012, 06:39 PM #1Junior Member
- Apr 2012
- East Hampton Connecticut
pewter- 2002 Pontiac transam
t Trans Am interior door panel cracking.
I have a Trans Am that both the interior door panel are cracking from having the windows open and tops off. What can be done to prevent further cracking?
09-24-2012, 08:04 PM #2Junior Member
- Aug 2011
- Troy, Illinois
Pewter- 2002 Trans Am
http://www.highperformancepontiac.co...air/index.html
Here is a nice link to help with cracked door panels.
09-25-2012, 03:59 AM #3Junior Member
- Apr 2012
% d Door Panel Repair.
Thanks, i'll check it out.
09-25-2012, 06:49 AM #4Junior Member
- Aug 2011
- Troy, Illinois
Sorry, the link got cut up, here is a working one.
http://www.highperformancepontiac.com/images/hppp_0711_firebird_door_panel_crack_repair/
09-25-2012, 07:34 AM #5Spaz is My Mentor
If your door panels get too messed up to fix try looking for 98 door panels. They seem to be the only yr that doesn't have these issues. IIRC in 99 they changes the way the door panels staples are placed and that is why they have cracking issues.
One more thing - in the article it doesn't state this but use some locktite on the bolts. The road vibrations will back the nuts off over time if they are not a lock nut style.Last edited by SMWS6TA; 09-25-2012 at 07:37 AM.
09-25-2012, 10:06 AM #6
They actually do mention it, but don't explain why...
A trip to our local hardware store netted us a handful of No. 4-40 machine screws in 7/8-inch length with matching washers and nuts, all for less than $1. We inserted a machine screw into each of the three holes, applied a dab of thread-lock, and tightened each nut until it was finger tight.
09-26-2012, 07:50 PM #7Junior Member
- Feb 2012
- canada
just check junk yards for the same panel any color make sure no cracks or a 98 i think does not crack and do the fix posted just get some
on a black car use exact match its what i used
SEM Paints (SEM38363) SEM Sand Free Prep Material Aerosol
SEM Paints (SEM38343) SEM Vinyl Prep Aerosol Spray
SEM Paints (SEM38353) SEM Plastic / Leather Prep Aerosol Spray
SEM Paints (SEM15013) Color Coat - Landau Black Aerosol
SEM Paints (SEM13023) Color Coat - Low Luster Clear Aerosol
09-27-2012, 07:31 PM #8
I got my passenger side fixed this evening.
Rather than follow the directions noted, I opted to use what I had readily available which was little plastic zip ties. I figured this would still allow a bit of flexing without causing any other issues. Hopefully my fix is just as good. I used standard epoxy to bond the splt.
Here are a few pics of the repair...
09-28-2012, 05:54 AM #9
I was one of those people in that thread and the reason why the panel started to crack is because of "stress". The reason why I say this is, once you take your door panels off you can see the pressure the staples are putting on the plastic panels. At first I was going to remove all nine staples as directed by "High Performance Pontiac Magazine" but after prying the staple loose I could see the problem, its the way the staples were installed.
The staples started out like any paper staple but intead of curling inward they curl outward and up at the points. I simply loosened all the staples by prying down on the points until they were horzontial. To be on the safe side I then removed five or six staples that were in the middle of the panel. So the only staples I left were the the ones on the ends and two equaly spaced apart in the center of the panel. I also applyed expoxy and fiberglass window screen the entire length of the panel on the inside. I don't think that was nessuary but I feel better knowning that I did.
Looking for Ebony Trans am door panel '01
By freddy_caprice in forum Parts Wanted / TradeReplies: 0Last Post: 07-23-2012, 04:51 PM -
interior question? craked door panel? need help?
By carnut7202 in forum General HelpReplies: 12Last Post: 05-25-2010, 06:16 PM -
Firebird Door Panel Crack Repair - Door Panel Pandemic
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-18-2007, 10:50 AM -
trans am door panel speaker help needed
By jw714 in forum Stereo and ElectronicsReplies: 2Last Post: 09-25-2007, 04:58 PM -
Door panel tops cracking
By proroc in forum Firebird / WS6Replies: 12Last Post: 06-22-2006, 05:37 AM
