Results 1 to 13 of 13
05-17-2010, 02:50 PM #1
interior question? craked door panel? need help?
ok guys i know this is a farily common problem from what i hear. I got in t/a today and nocited a small crack at the top of the door panel. i know it can be fixed but i cant find what section iti s under if any would could tell me where to look would be a great help. I figured there would be a sticky on it but i cant find one
05-17-2010, 05:03 PM #2Junior Member
- Jan 2010
- Oklahoma
- 2002 Pontiac Trans Am WS6
Hey there, I don't know where the other posts are at, but I just performed my own repair a week ago.
The way that I found to fix it was from another website. They said that the problem lies with the way the rubber piece at the top of the panel is stapled to the door pad. The way you fix this is to obviously take off the door pad and remove the staples that cause the stress on the plastic. I just removed the last 5 or so. Go to your local hardware store and get 'Machine head #4-40 1/2" bolts.' I believe that they have a phillips head on them, and they come with the nuts. There were 8 or so in the pack I bought for $1. Then you will need some epoxy to place on the back side of the panel, where it is starting to crack, before you put the new bolts in, and after you have removed the staples. I also used some mesh type material to go across the panel over the crack and then put the epoxy on top of it to give the panel more support.
Let me know if you have any questions, but this should save whatever is left of your panel before it cracks all the way through.
05-17-2010, 05:48 PM #3Senior Member
- Apr 2008
- Madison, WI
Instructions:
http://www.highperformancepontiac.co...air/index.html
Another good write up
http://www.ls1.com/forums/showthread.php?t=76192
05-17-2010, 07:16 PM #4Electrical Engineer
- Jul 2009
- North of the Motorcity
Here's how nasty my driverside was. It's actually out in the garage as we speak waiting for the glue to cure.
I used a series of clamps and bunji cords to get the crack flush and sealed up. Use a flashlight/shop light behind the panel to check how sealed up you are. Typically, the more light that doesn't get through, the closer the panel parts are together and this helps hide the crack better. This is where I spent most of the time on this project.
I would also suggest working carfully with the plastic, as overtime it becomes brittle.
The rubber/felt piece also has metal in it, so becareful not to put a huge bend in it, or it may create a sort of ripple finished product if not straightened out well enough.
Lastly, but most importantly, DO THIS TO YOUR OTHER PANEL. Although it may not need it yet, these steps can be taken as preventative cautions.
05-19-2010, 07:45 AM #5
thanks for the info guys. whish me luck
05-19-2010, 10:40 AM #6Electrical Engineer
- Jul 2009
I'll have a final result pic for you when I get home later so you can how it turns out.
05-19-2010, 01:48 PM #7Electrical Engineer
- Jul 2009
This is the passenger side progress (driver side needs more attention). Sorry for the crap cell phone pic.
Before
After
I used a razor blade to clean up loose pieces of stray plastic on the frontside after the glue dried.Last edited by KMdef9; 05-19-2010 at 01:51 PM.
05-19-2010, 02:19 PM #8Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
looks a lot better, good job
05-21-2010, 07:45 PM #9
yea it does look good. how and what did you use to get the crack to close up???
05-23-2010, 06:59 PM #10
http://s787.photobucket.com/albums/y...panelcrack.jpg
Oh ya! Look at mine...both sides are like that..Last edited by TransAmPhantom; 05-23-2010 at 07:08 PM.
05-23-2010, 08:13 PM #11
05-23-2010, 08:22 PM #12Electrical Engineer
- Jul 2009
05-25-2010, 06:16 PM #13
well thanks for the info on how u closed the crack. I wonder what would it take for GM to make this a recall. It shure would be nice if they did but they probley never will oh well life goes on
t Trans Am interior door panel cracking.
By trnsman in forum Firebird / WS6Replies: 8Last Post: 09-28-2012, 05:54 AM -
Door Panel Fix Question
By dschribs in forum Firebird / WS6Replies: 9Last Post: 04-02-2012, 02:41 PM -
Door Panel Insert question
By bberretta in forum Appearance SectionReplies: 2Last Post: 04-30-2010, 12:58 PM -
Firebird Door Panel Crack Repair - Door Panel Pandemic
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-18-2007, 10:50 AM -
Tail panel black 2001 SS and a plastic interior hatch panel that covers the speaker
By pbjones81 in forum Parts For Sale / TradeReplies: 0Last Post: 12-07-2006, 01:20 AM
