Results 1 to 11 of 11
    Jun 2009
    nor cal
    cooling fans aren't working
    Ive got a 98 z28 that ive had for a couple months now abd it's been having some cooling issues. the temp gauge usually sits at 100 until I hit traffic then climbs to 210 and the. Low coolant light comes on. Im thinking it could b a sensor but I really don't know. I swapped a hypertech 160 thermostat in and still having problems. I didn't realize the fans were not working until after I did the thermostat but I don't think it was from the swap. Any ideas?
    Also im thinking about doing a Trans cooler to. I have a gauge and when im going above 50 sits around 160 but when im below that it gets above 210. I'm guessing it would b from the fans but are those temps dangerous? It might have a shift kit but for sure no stall
    Jun 2009
    nor cal
    I know the temp gauge isn't right but still lost
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Have you checked your fan relays or swapped them to see if they're the culprit? Have you checked your coolant temp sensor to see if it's damaged or the wiring leading to the sensor?
    Jun 2009
    nor cal
    I haven't tried the relays but I will. Whay relays would be ok to swap? I looked at the temp sensor and it looked fine so does the wiring
    North Jersey
    2004 GTO M6
    You need to look under the hood at the fuse panel and look for what are the designated relay. Then you will have to look around the fuse block for a similar relay and pull that and remove the fan relay and insert the other relay in its place and run the car to see if the fans kick on.
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    What temps would you set your fans for on/off temps?.........
    Jun 2009
    nor cal
    I will try that and see how it goes.
    I think I should have my fans set around 160 since I have a 160 thermostat now. I think the car has been tuned but I want to have it done again to see what has already been done and I know there can be improvements
    Jun 2009
    nor cal
    I just went and checked out the relays. the fan relays for 1 and 2 are the same and fan 3 is different. which ones should I switch?
    I don't know if it makes a difference but when i got the car the a/c system was ripped out. could that have caused this?
    North Jersey
    2004 GTO M6
    Quote Originally Posted by pk222 View Post
    Check with your tuner. Something could have been missed or incorrectly adjusted during the previous tune.
    Jun 2009
    nor cal
    I'm gonna try. He runs the business out of his house and he's a pita to get ahold of. Anyone know of a good tuner in the oakdale or Modesto area?
    Jul 2012
    NorCal
    2002 Camaro SS M6
    No not in that area but in Campbell Ca, (near San Jose) theres TPSmotorsports.com. ?? I know thats a couple hours away but?
  1. Cooling Fans
    By kraemer94 in forum General Help
    Last Post: 09-18-2007, 07:40 PM
  2. cooling fans
    By 79Malibu in forum Stereo and Electronics
    Last Post: 04-27-2007, 07:00 PM
  3. LS1 Cooling Fans
    By oldsfreak in forum Parts Wanted / Trade
    Last Post: 03-05-2007, 04:59 PM
  4. Need LS1 cooling fans
    By Fire Chicken of Doom in forum Parts Wanted / Trade
    Last Post: 11-02-2006, 07:49 PM
  5. 98 LS1 cooling fans?
    By tigressws6 in forum General Help
    Last Post: 03-19-2006, 02:55 PM
