Thread: 4000 stall converter shift pts.
08-24-2012, 07:06 AM #1Member
- Aug 2011
- pittsburgh,pa
navy blue- 1998 camaro ss
Got a pt 4000 yank converter on the way and of course I'm sending the comp. out to get 're-tuned(frost). Not sure where he's gonna put the shift points. It shifts at 5500 now with all Boltons and 3.73 gears. Will he put them around 6000 or should I ask him to or what? Heads and cam are still stock, 98 camaro. Whats the highest rpms it can take, or what would be best?
08-24-2012, 07:36 AM #2
if you're still on the stock valvetrain I would recommend keeping the stock shift points. If you swap the valvetrain down the road then you can raise them. Just not worth the risk on stock springs to rev higher than stock rpms.
08-28-2012, 08:57 AM #3Member
- Aug 2011
- pittsburgh,pa
Damn I was hoping for a couple hundred more so I could really wind thisb bitch out with this 4000
08-28-2012, 11:32 AM #4
the stock cam is pretty much done at that rpm anyhow.....you may get a touch more but most likely you just come a step closer to floating the valves. Just not worth it in my opinion.
09-17-2012, 06:56 AM #5Junior Member
- Sep 2012
- Adams County, Ohio
gunmetal gray metallic- 1989 Trans Am GTA
6,200 but that's just me. Should have been shifting around 6 from the factory?
2 Shift solenoid ECM code After stall converter install
By wcboricua in forum Automatic TransmissionReplies: 6Last Post: 01-05-2011, 06:44 PM -
4000 rpm stall?
By tg580 in forum General HelpReplies: 4Last Post: 04-19-2010, 07:59 PM -
Is It smart to put a 4000 stall torque converter
By kams95ss in forum Automatic TransmissionReplies: 4Last Post: 02-06-2007, 03:41 PM -
WTB: 3600-4000 Stall!!!
By schtick in forum Parts Wanted / TradeReplies: 2Last Post: 08-23-2006, 09:00 PM -
WTB 4000-4400 Converter
By AutomagicLS1 in forum Parts Wanted / TradeReplies: 0Last Post: 08-03-2006, 04:37 PM
