Results 1 to 10 of 10
    Aug 2012
    brockton
    1996 impala ss
    5.3 turbo build any tips
    Acquired a 5.3 90k on it its gettin turbocharged looking for any tips tricks
    Check out this month's issue of GMHTP. They have a feature article on a budget 5.3 turbo build.
    Aug 2012
    brockton
    1996 impala ss
    Gmhtp? Gm high tech
    Aug 2012
    brockton
    1996 impala ss
    Checked didnt see it will check the newstand tommorro thank you sir
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Here you go: http://blogs.gmhightechperformance.com/6781111/gm-high-tech-performance-magazine/budget-53l/
    The only changes they made were a swap out to an F-body oil pan, a new timing set, car style intake for hood clearance and then after some testing on the dyno a new cam was installed. Probably want to avoid the DOD (displacement on demand) motors, although you can disable the system. They also recommended a donor engine with the 799 heads.
    Aug 2012
    brockton
    1996 impala ss
    Acquired a lm7 5.3 l out of a 1999 silverado 1500 4x4 90 k one owner it was a sweet score
    Aug 2012
    brockton
    1996 impala ss
    http://www.hotrod.com/techarticles/engine/hrdp_1104_594hp_53l_gen_iii_small_block_for_3252/viewall.html
    I think GMHTP's went somewhere north of 850 h.p. running E85.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    for turbo'ing the 5.3...
    Rod bolts, valve springs (or cam AND springs), rod bolts (if cam is done and power-band dictates) and open up that top ring gap to .026-.028" to keep the ends from butting under boost heat. Doing this with methanol, an M6 and about 16-17psi will make 700rwhp and it will live there with good tuning.
  1. Lq4 turbo build
    By 91lq4camaro in forum Forced Induction
    Last Post: 05-20-2019, 08:42 AM
  2. LQ4 turbo build
    By My00Z28 in forum Forced Induction
    Last Post: 04-27-2012, 07:37 PM
  3. Turbo build help
    By 200z28ss in forum Forced Induction
    Last Post: 02-19-2012, 05:11 PM
  4. Turbo V8 Build
    By SmallBCS10 in forum Forced Induction
    Last Post: 06-08-2011, 02:21 PM
  5. turbo ls1 build
    By turbols1317 in forum General Help
    Last Post: 09-27-2010, 09:40 PM
