Results 1 to 17 of 17
Thread: LQ4 turbo build
02-24-2012, 08:15 PM #1
LQ4 turbo build
Throwing some parts together and needing some ideas.
This is going to be a stock LQ4 build, using ARP mains, rods, and head bolts/studs... 315 heads, ls6 intake, truck manifold turbo build... I need help picking a cam. Thinking an ls6 cam would be good for now, what you guys think?
Hoping to start buying parts in the next couple weeks, and turbo will be first on the list.
Thanks
02-25-2012, 07:23 AM #2
here is a list of almost everything ill be getting to help pick a cam!
LQ4 Parts
LS1 Windage Tray
LS1 Oil Pickup Tube
LS9 Head Gasket
LS6 Intake
LS9 Valve Springs
Ported LS6 Oil Pump
LS2 Timing Chaing
GM LS7 Lifters
Hardened Pushrods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Piston Rings
Bearings
Turbo Parts
On3 76mm Turbo
Turbo Lines
Wastegate
Blow-Off-Valve
Intercooler and Piping
2 truck Manifold Flanges
Mandrel Exhaust Tubing
Turbo Flange
O2 BungsLast edited by My00Z28; 02-25-2012 at 07:26 AM.
02-27-2012, 06:57 PM #3
thinking of an ls9 cam now any input?
02-27-2012, 07:06 PM #4
Have you considered the EPP blower cam?
02-27-2012, 07:19 PM #5
Thanks
the lift on that cam is pretty big wouldnt i have to fly cut the pistons for it?
I know no FI build will be cheap but im doing a budget build on this... doing everything my self... that cam is kinda high in price for my ideas(i know tho it would probably be great tho)
02-27-2012, 07:25 PM #6
I'm not sure on fly-cutting, but I don't recall ever reading about people needing to on a stock LQ4 that have used it. I've just read nothing but positive reviews on it with everyone running blowers/turbos and that is why I mentioned it. I'm strongly considering it when I go into my motor when I up my current boost level.
02-27-2012, 07:27 PM #7
ya it does look like an awesome cam but then my build price jumps up like.....$1000plus? lol
02-27-2012, 07:35 PM #8
I know that on a LS1 with 241/317 heads there is clearance. Maybe call Bob at Brute Speed and ask the question. Like I said, a quick search on Google didn't say anything about needing to do that on the LQ4 either.
I would guess though that if they needed to be, the cost would be around $250. It was around $200 a few years ago.
02-27-2012, 07:42 PM #9
I looked on the site and it said there was no need to on the engines they used or something like that
02-27-2012, 08:03 PM #10
I really haven't did much research on blower cams yet as I'm probably a few years away still from wanting to increase my set-up. I just know that EVERYONE seems to rant and rave about that cam and it's performance on here and other forums.
Keep us posted on what direction you end up taking. Looking forward to seeing this come together for you.
FI is definitely a fun route to go
02-27-2012, 08:35 PM #11
Ya thanks a buddy and I are going to be working on this fabing everything for it just needed some ideas to get me started....
I'll be getting the turbo in two weeks and hopefully some tubing so I can fab up the hotside.
Any more info or recommendations would be great from any/everybody :-)
02-28-2012, 09:30 AM #12
well LS9 springs are out of the question because LPE emailed me back saying that the closed pressure was only 80#....lol
03-03-2012, 05:21 PM #13
03-05-2012, 09:46 AM #14
I've seen Patriot Gold (8401) 650 lift springs used before. Not sure on the PAC Racing 1218 springs.
03-05-2012, 10:02 AM #15
ya I'm looking at the Patriot dual springs now. $250 and they come with retainers, seals, and locks... same ones your talking about!
And im pretty positive im going to go with that EPP blower cam... probably going to be buying it after my paycheck on 3/16/12... cam and 7.4 pushrods... i ordered a set of "Sealed Power Premium Piston Rings" standard size they are Moly rings PN: E-921K... you think these will be fine?
Ill also be ordering Mains and Rod bearings "Sealed Power Race Performance Bearings" Main PN:152M, Rod PN: 8-7100CH anything bad with these choices?
Im hoping to have the LQ4 back together between this and next month with ARP Rod bolts, LS9 Head gaskets, OEM Felpro every other gaskets, EPP blower cam, hardened pushrods, LS7 Lifters, Patriot springs, new OEM head bolts, LS2 Timing chanin, Ported LS6 oil pump, and some small things here and there...
Thanks
03-05-2012, 05:07 PM #16
also just won a 45mm turbosmart hypergate wastegate on ebay for $220 brand new!
04-27-2012, 06:37 PM #17
Just put my order through on the Brute Speed Forced Induction Cam(EPP Cam) once i get that i can put the bottom end together!!!
Lq4 turbo build
By 91lq4camaro in forum Forced InductionReplies: 4Last Post: 05-20-2019, 07:42 AM -
Turbo build help
By 200z28ss in forum Forced InductionReplies: 2Last Post: 02-19-2012, 04:11 PM -
My turbo ls2 build
By blackmagicturbo in forum Camaro / SSReplies: 68Last Post: 06-15-2011, 06:26 AM -
Turbo V8 Build
By SmallBCS10 in forum Forced InductionReplies: 2Last Post: 06-08-2011, 01:21 PM -
turbo ls1 build
By turbols1317 in forum General HelpReplies: 27Last Post: 09-27-2010, 08:40 PM
