    Feb 2008
    SOUTH CAROLINA
    BLACK
    Oil pressure sending unit
    If i have to pull the manifold i will just watch the needle jump around... Is there any other choice? yea i searched, did not like the answers.
    Feb 2008
    SOUTH CAROLINA
    BLACK
    THE unit cost me $40 i will take it back if i have to pull the intake, that is stupid.
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    You don't have to remove the intake but it is much easier. Honestly, it isn't that hard to remove it. My first time it took two hours now I an down to taking it out and installed in about 30 minutes or so.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Junior Member nathanWS6's Avatar
    Jan 2012
    spring hill,FL
    2000 trans am ws6
    no need to pull intake just make sure you bought the socket to replace it..
    when doing my LS1 to LS6 intake swap i broke mine then while re-installing intake i broke the new one!! LOL
    i took it back and they gave me a replacement and i installed that one in like 10mins
    eibach sportline springs,kyb shocks and struts,adj. panhard,LCAs with relocation brackets,strut tower brace, sub-frame connectors,poly motor mounts, LT headers,magnaflo catback,ORY pipe, SLP lid w/K&N, ram air mod,egr delete,PP TB,1000CFM MAF housing, LS6 intake,160 T-stat, tune by frost
    Apr 2010
    Alabama
    Black/ Silver
    I broke mine and I didn't need a socket it turned by hand. I just used two fingers in the whole and turned it.
    job is much easier with intake off.....pulling the intake isn't that bad at all. I'd much rather pull the intake than do the brakes or something like that.
    Arizona
    Pulling the intake is a piece of cake.
    Fuel rails pop right out and can be laid off to the side without disconnecting the fuel line.
    It's a dry intake so no antifreeze to deal with. Lift it up and out, probably only weighs 3 lbs. It's the easiest intake on an engine I've ever pulled, no water, no gaskets or gasket sealant to mess with, really just all around easy,,,,did I say it was easy?
    I'd much rather pull the intake than try to fit my arms under the cowl.
    This - intake can be off/on and job done in 30-45 mins vs slashing the hands and arms with the cowl while blindly trying to get the OPSU off/on. Also have fun looking for the wire harness if it falls down away from the OPSU.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Just pull the intake and be done with it. You can't screw anything up because there is nothing to screw up.
  1. Oil pressure sending unit help!
    By ChevyMan in forum GM Trucks
    Last Post: 06-23-2019, 01:51 PM
  2. Oil Pressure Sending Unit
    By kb274868 in forum External Engine
    Last Post: 01-12-2010, 06:30 PM
  3. Oil Pressure Sending Unit
    By driftpin in forum External Engine
    Last Post: 03-18-2009, 01:39 AM
  4. oil pressure sending unit
    By emotionalpiracy in forum General Help
    Last Post: 02-16-2008, 06:54 PM
  5. Pic of oil pressure sending unit??
    By LETHALxLS1 in forum External Engine
    Last Post: 05-11-2007, 08:32 PM
