Results 1 to 15 of 15
Thread: oil pressure sending unit
02-11-2008, 02:44 PM #1Member
- Oct 2007
- Union Beach, NJ
triple black- 02 z28 m6
anyone have any suggestions or tricks to finding it and removing it? the last time i took off the intake manifold i couldnt figure out how to get it off or find it, then broke it and id rather not do that again. (im retarded)
02-11-2008, 03:09 PM #2Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
gotta pull the intake...
its in the back drivers side corner of the engine...
will try to locate pic...
02-11-2008, 05:01 PM #3
This man speaks the truth. ^ The only trick I have for you is to practice your patience lol. It's not that hard compared to how much of a pain in the ass it is...Took me about an hour and a half to do, and the hardest part is taking loosening/ tightening the manifold bolts. There is NO way around it...
02-11-2008, 08:50 PM #4Member
- Oct 2007
- Union Beach, NJ
you have to remove the oil pressure sending unit from the intake manifold before you pull the manifold
my goal is pulling the manifold
i just dont want to break the opsu this time
i remember where it is locationally
im just looking for suggestions on how to locate it by hand and what to do to disconnect it from the manifold
02-11-2008, 08:52 PM #5Member
- Oct 2007
- Union Beach, NJ
i never had a problem getting the intake manifold bolts out
though, unless you count the sharp things sticking out of the awning cutting of my friend and I's arms
i think i spent like 3 hours screwing the last bolt back in
hurray for manual tools
02-12-2008, 04:14 AM #6
the sender isn't connected to the intake at all. What happens normally is people break it off with the brake booster hose. You just have to go slow when sliding the intake out and work that booster hose over the sensor on it's way out.
02-12-2008, 09:48 AM #7Member
- Mar 2007
- NC
NBM- 1998Z28
And with the proper sensor socket (I bought mine from NAPA) you can remove and replace the oil pressure sending unit WITHOUT pulling the intake manifold. A regular socket is too big around to fit. The socket from NAPA has thin walls.
02-12-2008, 10:20 AM #8Senior Member
- Jul 2005
- Jacksonville, FL
I'd definitely try the socket first before going through the trouble of removing the intake.
02-13-2008, 08:31 PM #9Bone it like you own it
- Sep 2005
- TEXAS... U mad?
the socket has not much to do with it... its the location that causes you to remove the intake... unless you have extremely small hands...
02-14-2008, 04:44 AM #10
yeah, unless you're a midget contortionist with hands the size of my 4 year old boy just plan on taking the intake off.
02-14-2008, 09:32 AM #11Bone it like you own it
- Sep 2005
- TEXAS... U mad?
could always use a 2" hole saw and just go straight down thru the windshield and dash.... then that socket with a long extension would do the trick....
02-15-2008, 10:29 AM #12Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
i know, I remember it tooke me an hour to switch the last spark plug on the passenger side, i dont even want to remember it.
02-16-2008, 06:41 PM #13Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Underside, and plenty of patience.
02-16-2008, 06:53 PM #14Member
- Nov 2007
- SATX
you did it from the underside? i will try that on my next tune up. thanx
02-16-2008, 06:54 PM #15Bone it like you own it
- Sep 2005
- TEXAS... U mad?
there is a thread on this here. guys gonns post pics of the tools he used to make it a breeze.
Oil pressure sending unit help!
By ChevyMan in forum GM TrucksReplies: 8Last Post: 06-23-2019, 01:51 PM -
Oil Pressure Sending Unit
By kb274868 in forum External EngineReplies: 6Last Post: 01-12-2010, 06:30 PM -
By driftpin in forum External EngineReplies: 1Last Post: 03-18-2009, 01:39 AM -
By uLs1a in forum Western MembersReplies: 7Last Post: 02-20-2009, 05:06 PM -
Pic of oil pressure sending unit??
By LETHALxLS1 in forum External EngineReplies: 7Last Post: 05-11-2007, 08:32 PM
