Results 1 to 2 of 2
04-06-2006, 05:35 PM #1Bigrob92rsGuest
Transmission Installation Problem
Well ive been trying to install my stock transmission onto a 89 350 tbi engine i bought for my 92 camaro rs. And the problem I am having is that it wont go together as easy as the stock to the stock motor did. Also when i do get it lined up i have to use a couple of bolts to pull it together and then the torque conv. wont spin freely like the stock one. And yes the torque conv. is in all the way. Im not sure but every mechinic I talk to says that it should bolt up with no problem but in this case its not. If anyone has any idea they would be appreciated.
04-16-2006, 04:54 PM #2
did the converter go in with three 'clicks'? if not, then it's not all the way in. one way to check, is to try and put your fingers between the converter and trans from the bottom. if it's a stock converter, then you shouldn't be able to do it.
Question: Transmission cooler installation
By dethinboots in forum GTOReplies: 12Last Post: 04-22-2015, 08:57 AM -
Auxilliary Transmission Cooler Installation
By pajeff02 in forum Automatic TransmissionReplies: 4Last Post: 09-08-2011, 04:24 PM -
Help: Transmission mount installation trouble
By SP33Daddict in forum General HelpReplies: 13Last Post: 03-08-2011, 06:53 PM -
T56 Installation Problem
By Wesman in forum DrivetrainReplies: 1Last Post: 11-07-2008, 10:17 PM -
Rear Brakes Installation Problem!!
By adham in forum General HelpReplies: 18Last Post: 06-07-2007, 08:15 AM
