Results 1 to 14 of 14
03-05-2011, 11:21 AM #1Junior Member
- Nov 2010
- Rocky Mount, VA
Mystic Teal- 1999 Trans am
Transmission mount installation trouble
Ok so I got my new transmission mount in yesterday and today I got to work installing it. I took off the crossmember, took off the old mount and installed the new one. After trying to put the crossmember on, I realized that it is now too far away from the bolt holes to make contact with the bolt holes. The part I received is only one piece and is different from the two piece mount that was on before. So now Im trying to figure out if I need to order a new part or if there's something I'm doing wrong. The new tranny mount I received looks like this:
Please help soon I was hoping to finish this today. Thanks.Last edited by SP33Daddict; 03-05-2011 at 11:46 AM.
03-05-2011, 11:28 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Try using a longer bolt to draw it closer first, then switch to the original bolt. Or you could try using a bottle jack to raise the crossmember. How far away is the crossmember from the frame?
03-05-2011, 11:31 AM #3
What year is your car? That looks like the style I kept finding when doing part searches. I just went to the local dealership and got the OEM one, and paid $96.00, and it looked nothing like what I kept finding on the internet.
03-05-2011, 11:35 AM #4None Shall Pass
- Jan 2010
He has a 99 T/A.
OP, you do have the tranny supported by jack I'm assuming? Have you tried raising it up?
03-05-2011, 11:53 AM #5Junior Member
- Nov 2010
- Rocky Mount, VA
Yes its a 99. The part I ordered said it was for 93-02 Trans Am or Camaro. I usually don't order parts that are that vague but after looking at a few other ones on the web they all looked close to the same so I bought it. Oharam, was the OEM part you ordered two pieces or one? Is there a difference between Trans am and Camaro tranny mounts?
The distance depends on how you hold the crossmember because the bulge is in the center, but if you hold it to one side, the other side is about 4-6 inches from the hole.
Yeah the tranny is supported by a jack and the jack is pretty much maxed out b/c its a 2200 pound jack and it can't lift the whole car but the transmission is jacked up about as high as I could get it.
03-05-2011, 12:03 PM #6
I assume that you tried rotating the mount to see if it helps? Have you tried letting the bolts loose and see if gives you more clearance? Can you post a picture of the mount installed so we can see the clearance issue?
03-05-2011, 09:44 PM #7Junior Member
- Nov 2010
- Rocky Mount, VA
I did try rotating the mount but this one only fits one way and the bolts are loose. Is there a full write up on tranny mount installation with pics?
03-08-2011, 07:23 AM #8
is pretty straight forward. Loose the bolts jack the tranny up some, remove the crossmember and install the new one.
Are you sure they gave you the right tranny mount? Do you have a part number? I think the mount for manual is different than auto. If you can post a pic of the clearance issue it will help us to give you a better answer. I have a feeling that you have the wrong tranny mount.
03-08-2011, 10:53 AM #911 years of bangin gears
- Jan 2009
- North Jersey
I also think that's the wrong mount.
03-08-2011, 12:13 PM #10Senior Member
- Jan 2010
- texas
silver- 2000 formula
i did a poly mount......and it took all of 5 min to bolt it in
03-08-2011, 02:24 PM #11Junior Member
- Nov 2010
- Rocky Mount, VA
I fixed it!! The jack I was using was low on hydraulic fluid and it was weak so it was slowly lowering. I got out my other jack and jacked up the crossmember and it worked fine once the bolt holes lined up. Thanks for the help.
I took it for a good drive today and it seems to have taken care of everything which is awesome because I bought the car at a deep discount under the impression that the tranny was slipping but it was just a really worn mount. The guy I bought it from was wealthy and had just bought a new Pontiac Solstice and was looking to get rid of it.
03-08-2011, 02:26 PM #12None Shall Pass
- Jan 2010
Glad to hear. I figured it was something simple.
03-08-2011, 02:30 PM #1311 years of bangin gears
- Jan 2009
- North Jersey
Nice steal!! Enjoy.
03-08-2011, 06:53 PM #14
nice! now get a new jack lol.
Question: Transmission cooler installation
By dethinboots in forum GTOReplies: 12Last Post: 04-22-2015, 08:57 AM -
Auxilliary Transmission Cooler Installation
By pajeff02 in forum Automatic TransmissionReplies: 4Last Post: 09-08-2011, 04:24 PM -
clutch/transmission trouble
By 99maroz28 in forum Manual TransmissionReplies: 2Last Post: 09-08-2011, 10:47 AM -
Transmission trouble
By thull97 in forum General HelpReplies: 0Last Post: 08-12-2009, 08:55 PM -
Transmission Installation Problem
By Bigrob92rs in forum Automatic TransmissionReplies: 1Last Post: 04-16-2006, 04:54 PM
