Results 1 to 17 of 17
Thread: Flickering oil PSI gauge?
08-04-2012, 03:06 PM #1
So my oil PSI gauge flickers sometimes, its nothing extreme like 20-60psi but when I'm sitting at a light then it'll slightly flicker the needle around 40psi (normal idle psi) under acceleration its fine and holds normal pressure (about 60psi). Car has 79k miles and I use Pennzoil platinum 5-30... anybody else seen this? I know these gauges suck
08-04-2012, 04:36 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Could be the OPSU having an issue, a slightly loose wire connection, or just the guage itself. I wouldn't worry about it too much. You could go with an aftermarket guage setup just to be safe.
08-04-2012, 05:32 PM #3Your friendly policeman
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
Mine does the same thing. Typically it only does it once the car has been driven for awhile, and it only does it with the car in gear. Not too worried about it since pressure seems fine otherwise.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
08-04-2012, 05:35 PM #4
08-05-2012, 01:10 AM #5
Or this one....My oil gauge moves to the beat of my music
No shit! If i mute the stereo or shut it off..it stays on the correct pressure but when the musics playing it moves with the beat of the music!!The stereo is the factory monsoon - no aftermarkets-..now it has been replaced once under warranty(the stupid illumination lights went out,,,and so did this one eventually)..possible bad ground with stereo? If so why would this affect the oil guage?
08-05-2012, 04:39 AM #6
Mine flickered a bit and read a little low,put a new OPSU in when I did the LS6 intake and no more flicker and I have a good strong reading which is backed up by how the car runs.
2010 Camaro SIM 2SS/RS A6
1999 TA A4 NBM
12.265 at 110.52mph
08-05-2012, 05:50 PM #7
08-07-2012, 01:04 AM #8
08-07-2012, 04:00 AM #9
OP - your oil pressure readings match mine. I would suspect the same as posted by Knight - just be damn careful poking around behind your intake. There is a great writeup on here by junkyarddog on plumbing in an aftermarket gauge. I know the temp gauge in anything other than a '98 model year car is a POS, but the oil pressure gauge from the factory seems to work well and I have seen few complaints on here.
08-07-2012, 04:02 AM #10
08-07-2012, 08:36 PM #11
Where? against the firewall? No to the secondary air at least I never touched it...It seems to have started after the 1st factory Monsoon stereo went out and second installed at GM dealership? But unfortunately i cant say that for sure No to any other accesories,No aftermarket alarm...The only work i had done was the LT`s,and when they did that they put in plugs and MSD wires----but it didnt happen til way after that so? kinda a stumper but not serious just annoying.huh ive got my OP gauges needle boppin to the beat all i need now is the fog and mirror ball
NOT!
08-08-2012, 08:31 PM #12
Might not be a bad idea to pull the head unit yourself and look everything over. I have the books for the '02 and can pinpoint the ground for the system. The one on the back of the head just seems to be the one people have had issues with, usually after a secondary air delete as they don't realize the back bolt is also a ground.
08-08-2012, 10:58 PM #13
08-09-2012, 03:59 AM #14
Very back of the head. With a mirror you can see it from up top.
08-09-2012, 08:24 AM #15Former Mopar Man
- Jun 2011
- Branchville, NJ
Gauges on our cars suck !!!
08-09-2012, 08:27 PM #16
Thanks!
08-13-2012, 12:49 AM #17
[QUOTE=dcrghujuikhjd;2796866]. The North Face Jacket
THe North Face Outlet
North Face Jackets Men
[url=http://www.thenorthfacesclub.com/north-face-equipment-c-32.html]North Face Equipment[/
flickering lights
By TheOne in forum General HelpReplies: 8Last Post: 10-29-2013, 09:05 PM -
Flickering headlights
By 1986camarojoe in forum CorvetteReplies: 11Last Post: 12-12-2009, 03:20 AM -
flickering lights
By ricefordiner in forum General HelpReplies: 10Last Post: 08-15-2009, 08:40 PM -
99 camaro ss oil pressure gauge flickering
By crd in forum General HelpReplies: 8Last Post: 09-04-2007, 09:37 PM -
*?Flickering Headlights?*
By SicWs6 in forum Firebird / WS6Replies: 8Last Post: 07-24-2007, 08:45 AM
Help Mr.Wizard.....
