Results 1 to 10 of 10
Thread: Bleeding Clutch Hydraulics
07-21-2012, 04:53 PM #1Member
- Jun 2012
- florida
How do you bleed the slave cylinder, does it have to be done with the master attached and trans pulled back to access the bleeder fitting. Seems very strange.
07-21-2012, 05:12 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Go to forums and look for the sticky on this procedure. Also look for the drill mod. I recommend it.
07-21-2012, 05:22 PM #3Member
- Jun 2012
- florida
I went with the tick cylinder so I dont have to drill it. I will look at the sticky
07-23-2012, 07:32 AM #4Spaz is My Mentor
You'll need another person. One on the pedal and the other moving back and forth between the slave and the master.
You'll need:
I want to say it's a 10mm I used a box wrench,
a small bottle that you can hang near the slave
Tubing
Remove the reservoir cap off the master. Next slide on some tubing so the fluid does make a bigger mess. Put some fluid in the bottle not much maybe a 1/4, no more then a 1/3. Place the tub into the bottle where the tube is submerged into the fluid. This is so in case the guy on the pedal lets off before you can close the valve it doesn't suck air back up. This is time consuming process. Open the valve, have the guy press the pedal down, close valve, pedal is release (first few times they will need to lift pedal up themselves), after every other cycle you need to check the fluid level in the reservoir, do not let it empty. Repeat till pressure feels right. It can take a while.
Now if you have a mitty vac - I'm not sure of the procedures, (I need to add that to my Christmas list)
Great choice.
07-23-2012, 09:04 AM #5Member
- Jun 2012
- florida
bleeding
My tick came with an external bleeder hose so I guess I can button up the transmission and bleed it last then just tie wrap the bleeder hose to something, right?
07-23-2012, 12:13 PM #6Spaz is My Mentor
Yes, run it along the hydraulic hose from the master to the slave. Hell zip tie together and remember to place them behind the heat shield otherwise it will cook the fluid and you'll not be able to shift.
07-23-2012, 12:32 PM #7Member
- Jun 2012
- florida
If I remove the brake master cylinder out of the way do you think it would be easier to get at the clutch master cylinder?
07-23-2012, 07:19 PM #8Spaz is My Mentor
It could but it makes more work then necessary. Getting it out isn't the problem its getting it back in. There is a trick that helped me. Find a drill bit that is one size larger and open the 2 holes out a little bit. This will give you some extra wiggle room. You have to drive from the inside of the car out. Don't press to hard and push through the break master cylinder.
Also there is a mounting tab that connects one of the break lines to the shock tower, remove it to help move around, don't forget to reinstall it.
07-24-2012, 04:25 AM #9Member
- Jun 2012
- florida
SMWS6TAm was your exhaust connected when you replaced the master?
07-24-2012, 06:22 AM #10Spaz is My Mentor
Yes, I told you in another thread that I've dropped my tranny 3 times, one of those was with the stock exhaust and the other 2 was with LT's.
The exhaust really doesn't interfere with the installing of the master cylinder. The break booster does, you almost have to do it blind. I used a second person to push the bolts in the holes while I tried to get a nut on a couple of threads. Once I did all I had to do was tighten them.
WTB: Clutch Hydraulics for T56 from an LS1
By kurider in forum Parts Wanted / TradeReplies: 3Last Post: 09-11-2015, 07:53 AM -
Clutch Hydraulics
By johnfin in forum Firebird / WS6Replies: 6Last Post: 10-07-2012, 03:47 PM -
Wish list for new hydraulics/ clutch
By Spikito in forum Manual TransmissionReplies: 32Last Post: 12-07-2010, 09:10 AM -
Help: Clutch hydraulics failed
By dannyo210 in forum Manual TransmissionReplies: 13Last Post: 06-26-2009, 01:20 PM -
Need info/help w/clutch hydraulics and new clutch
By OreoLt1 in forum DrivetrainReplies: 5Last Post: 03-11-2006, 05:16 AM
