Thread: front door panel removal
04-06-2006, 10:20 AM #1meiselGuest
i am just about to replace the speakers in the front door of my 99z ttops with inifinity 62.7is (thanks for all the advice), but i forgot to print the thread that had the step by step pics of how to get the door panel off. if anyone can help me find it asap that'd be great!
04-06-2006, 12:37 PM #2Rock-n-Roller
- Jul 2005
- OHIO Go Buckeyes!
Arctic White- '07 Trailblazer LT
This is for my '99 Trans Am but a Camaro should be very similar.
1) Remove 1 screw to remove panel. You might be able to get the door trim panel off without removing this piece but I've always removed it when I take the panels off.
2) Lift up on the control panel to pop it out. Unplug the 3 wiring harnesses going to the buttons.
3 & 4) Remove screw and pry off the lock stem. Pull the panel out just a little so you can remove the courtesy lamp. Once the lamp is unplugged remove the panel.
5) Remove the large phillips head screw behind the panel you just removed.
6,7 & 8) Remove the 3 other large phillips head screws used to hold the door panel in place. The screw at location #8 is down inside the map pocket.
Now lift up and toward you to remove the trim panel. Be sure to un-plug the factory tweeter.
There are molded hooks on the back of the trim panel. They are used to hang the trim panel from holes that are in the door. One of these hooks is right next to the mid-woofer. Use caution here so that you don't poke a hole in your new speakers when you go to put the trim panel back on again.
04-06-2006, 02:42 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
The window motor replacement sites have insts on how to remove the panels - http://shbox.com/page/windowmotor.html
04-07-2006, 05:39 AM #4Detailing + Design
- Pittsburgh, PA
rascal, get a mod to make that a sticky!
Help: Door panel removal
By davidz28 in forum Camaro / SSReplies: 6Last Post: 02-14-2011, 05:53 PM -
roof panel removal
By wu802 in forum Camaro / SSReplies: 21Last Post: 10-25-2009, 07:14 PM -
Help: GTO door panel removal
By John Carlson in forum GTOReplies: 4Last Post: 07-12-2009, 03:35 PM -
Firebird Door Panel Crack Repair - Door Panel Pandemic
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-18-2007, 10:50 AM -
Front door panel speakers
By Zboner in forum Stereo and ElectronicsReplies: 8Last Post: 03-24-2006, 12:52 PM
