    Redmond,Wa.
    2004 Pontiac GTO
    GTO door panel removal
    Does Sarge or anyone else know how to get the inside door panel off on 2004 GTO? I got all the screws out and the top side window defroster off but it won't lift off. I got one screw out behind the inside door handle. I've got a sticky lock mechanism, but can't get at it. The car has only 15000 miles,but is out of warranty. 5 years old. Supposed to be a problem with the early locks. Mine is below the break point vin of 4L225024. Maybe Pontiac still has to fix it.
    Junior Member Mich's04's Avatar
    New York
    Cosmos Purple
    2004 GTO M6
    I'm assuming you have the door lock knob off too. So if you are totally sure you have all the screws out, and the plastic door panel clips loose. With the window down, tilt the bottom of the door panel towards you a little and wiggle it with some upward force to jog it free. They can be a little stubborn.
    I had mine off a few weeks ago to change out the door lock actuator.
    Good luck!
    04 Cosmos Purple M6, SAP Grills & Spoiler, '05 Hood, Procharger, TrickFlow 515 HP H/C Kit, SLP LT Headers/LM II, '05 Big Red Brake upgrade, Drag bags, Holden CV8R wheels, GMM Ripshifter. Tuned by New Era: 515 rwhp/471 ft.lbs. Retuned by J&J Speed: Speed Density tuned 586rwhp/ 492 ft.lbs.
    Redmond,Wa.
    2004 Pontiac GTO
    Door lock knob
    No, I don't have the lock knob off. How does it come off? It's square, not round. Does it pull off, or what?
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by John Carlson View Post
    the red round spot on the side of the lock button, there is a small indent, use a small flat head and pop the bottom of the red spot out (its what locks the button down in the door panel)
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    Phantom Black Metallic
    2004 GTO
    Mine are both stuck so I'm going to have to do this also. I already bought two new actuators.
  1. Help: Door panel removal
    By davidz28 in forum Camaro / SS
    Last Post: 02-14-2011, 05:53 PM
  2. roof panel removal
    By wu802 in forum Camaro / SS
    Last Post: 10-25-2009, 07:14 PM
  3. Firebird Door Panel Crack Repair - Door Panel Pandemic
    Last Post: 10-18-2007, 10:50 AM
  4. Rear Panel Removal?
    By 99_LS1 in forum General Help
    Last Post: 04-29-2007, 05:23 PM
  5. front door panel removal
    By meisel in forum Stereo and Electronics
    Last Post: 04-07-2006, 05:39 AM
