Results 1 to 20 of 28
07-17-2012, 04:35 PM #1Junior Member
- May 2011
- Farmingdale, NY
Black- 1998 Pontiac Trans Am WS6
Adjustable Lower Control Arms & Panhard Bar
Hey guys looking for some help. I have a relatively stock '98 WS6, but I'm looking to upgrade the rear, lower it, etc.
I'm looking to slowly upgrade the rear suspension before I go with a 9", I have SFC's and now want to replace the LCA's and go with an adjustable panhard bar. I'm thinking I want to go with all adjustable items because hey you never know....
The car will be predominantly a weekend car but maybe a few runs at the track. For the LCA's what kind of adjustable do I want? I see single and double adjustable types, what is everyone running....Pro's / Cons.. What is actually easiest to adjust on the car?
Also what ends are you guys running? Poly or roto?
Any help would be great, thanks in advance...
07-17-2012, 06:34 PM #2
I'm running the on-car adjustable PHB from UMI. Zero issues. Roto-joint end version.
My LCA's are non-adjustable though from BMR. Have them hooked up to the relocation brackets welded to the 9". Again, no issues and my wheels are perfectly centered.
I'd get both from UMI. On the LCA's, single adjustable will allow you to adjust the length, but you'll need to remove one end first. The double adjustables you can adjust without removing them.Boost gets you laid, unless your name is Jon.
07-17-2012, 07:18 PM #3Junior Member
- May 2011
- Farmingdale, NY
35th-thanks for the info, I figured one version could be adjusted on the car and one couldn't....thanks for the confirmation
Ok I was definately thinking of going all UMI. I dont want to post links on here but I'm thinking in terms of LCA's from UMI im down to one of the following:
Part #2039-> F-Body On-car Adjustable Control Arms- Poly/Roto-Joint
Part# 2017-> F-Body Double Adjustable Control Arms
Part# 2035-> F-Body Double Adjustable Control Arms- Roto-Joints
Part# 2018-> F-Body Adjustable Lower Control Arms w/ Polyurethane Bushings
I like the idea of the double adjustable, but the #2039 or 2018 seems like it might give me the best ride around town as the car is pretty much a weekend cruiser right now. I feel like the all roto joints (#2035) might make the car even rougher to drive around town...and #2017 seems more tailored to pure racing.....Any thoughts?
For the panhard bar I'm sure the same selection logic applies...
Once again thanks for the insight.
07-17-2012, 07:47 PM #4Spaz is My Mentor
I have the on-car single adjustable with roto and mine is consider lowered. Rides real good. Don't forget to consider an adjustable torque arm. That will effect the ride a little more then the the lca's. Reason being that as you drop in height the pinon angle changes. In order to get it correct again the torque arm needs to compensate.
When you do the TA look at getting it off the tail cone. I didn't go with the shorten TA because when I talked with the UMI guys told me that because I'm lowered with LT headers and ORY, if I relocated the TA to the tunnel brace I would hit every speed bump and scrape bad. It's great for track only cars but for street not so much.
I'll dig up my part numbers for you to look at.
You'll also need an adjustable PHB too.
I'd wait for sway bars until after the rest is done.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
07-18-2012, 01:10 PM #5Spaz is My Mentor
Here are the UMI part numbers I have and what I paid for.
Adjustable Torque Arm # 2205 $300
Torque Arm Relocation Kit for Transmission Cross-member # 2207 $250
LCA - On Car Adjustable with Roto Joints # 2239 $210
PHB - On Car Adjustable with Roto Joints # 2037 $140
2 point Subframe connectors # 2001 $150
Tower Strut Brace # 2005 $70
07-18-2012, 06:09 PM #6
I run alot of UMI products on my drag car but on my street car I am using Founders. Both are great manufacturers.
07-18-2012, 06:19 PM #7Junior Member
- May 2011
- Farmingdale, NY
Thanks for the info. I think I'm going to go with 2239 for the LCA's. My question is if I replace the rear am I going to have an issue attaching it to relocated attachment points. I assume with the poly and roto joint they will allow me to install on most any rearend.
Also think, I'll go with the 2037 for the panhard bar.
Did you feel a nice difference when you upgraded?
The torque arm will be down the road.
07-19-2012, 07:19 AM #8Spaz is My Mentor
You should have no issues with an aftermarket rear because they are made to our car's brackets. The only one that may need a relocation bracket will be the PHB. Reason why is the exhaust can hit it when lowered.
I had the 2pt SFC's and TSB for 18 months prior to the other stuff. The day I put the SFC's on I immediately notice that the car felt tighter, after I did the other stuff with Hotchkis springs and new shocks it really handles great. Launching is very good, it doesn't want to kick out and keeps the power to the pavement. I used to have a lot of wheel spin prior to the LCA's/PHB/TA now not so much.
07-19-2012, 10:44 AM #9Member
- Jan 2009
- Pa
Hey guys. Thanks for the UMI mentions!
Let me know if you have any questions now that I'm subscribed to this thread...
thanks
ramey
07-20-2012, 11:40 PM #10
07-21-2012, 07:04 AM #11
http://www.umiperformance.com/catalog/index.php?main_page=roto_joint
07-21-2012, 07:14 AM #12Member
- Jan 2009
- Pa
Thanks Jon. I had this marked to reply and voila, there it is.
DM, let me know if I can clarify anything. Basically the Roto-Joint offers the benefits of a rod end with some cushioning and quietness.
07-21-2012, 02:26 PM #13
Oh i see! Theres so many Abbreviations sometimes
Some i know right away some i have to ask,,After theyre decoded its an aha moment.Yeah as of now i have poly--(hey i know that one
) bushings on my LCA`s,Adj. PHB and shocks,TA and motor mounts....Ive heard good and bad about poly but i already have had them for 5 years w/ no problems but i still have alot of other suspension upgrades in the future( like a whole front end TA etc) so its good to know and learn from the guys who have the same type of cars to get a general idea of whats what! Thanks for your help!
07-21-2012, 02:27 PM #14
07-21-2012, 02:47 PM #15Member
- Jan 2009
- Pa
07-21-2012, 02:58 PM #16
^^ OK no problem soon as i get the bucks!!
07-21-2012, 03:01 PM #17
.................Also while were here taliking about suspension parts ...Whats the read on styles...Squared off -vs- round tube ? LCA`s etc....
07-21-2012, 03:05 PM #18Member
- Jan 2009
- Pa
We actually don't rank our products based on strength. Round vs square vs rectangular are all so much stronger than stock, we ask customers to pick based on the appearance they like.
Chromoly parts tend to be one wall thickness thinner than mild steel. The strength is roughly the same but CrMo is lighter due to the thinness. Both are adequately strong.
07-21-2012, 03:16 PM #19
^^ Thanks...Yeah anythings better then the hollow stamped stockers--thats for sure!!
07-21-2012, 03:46 PM #20
I run damn near the entire UMI catalogue on our car -- their stuff fits, functions perfectly, looks great and is so much better than what the General installed. As our car is not lowered, I run non-adjustable rear suspension components, with the exception of the tunnel mount torque arm. Moser's 12 bolt rear slid right into place and the double adjustment on the torque arm allowed me to dial in the pinion angle. Once you have your suspension in place, unless you then change out other components, it is unlikely that you will be messing with the settings. I wouldn't hesitate to go with single adjustable pieces as you simply have to remove a bolt to drop it and change the length should the need ever arise.
UMI on car adjustable control arms/ panhard bars
By Whamhammer in forum Suspension and HandlingReplies: 15Last Post: 12-04-2014, 03:16 AM -
Question: Lower control arms and panhard bar
By 98maro in forum General HelpReplies: 17Last Post: 04-08-2010, 06:15 PM -
Question: lower control arms and panhard bar
By o2 double s camaro in forum Suspension and HandlingReplies: 4Last Post: 09-26-2009, 06:41 AM -
Wanted: Adjustable panhard rod and rear lower control arms
By smkeater911 in forum Parts For Sale / TradeReplies: 0Last Post: 02-18-2006, 08:41 PM -
By smkeater911 in forum Parts Wanted / TradeReplies: 0Last Post: 02-18-2006, 08:40 PM
