09-15-2009, 07:42 AM #1Junior Member
- May 2009
- canada
black- 2002 camaro ss
lower control arms and panhard bar
Umi sells single and double adjustable lower control arms and panhard bar which one is the better option, can someone tell me what the differences are. I know its the both sides that can be adjusted but why should i buy the double adjustable ones do i need it or not.
09-15-2009, 10:42 AM #2
With a double adjustable bar, you can adjust it on the car without dropping one end out of the mount.
09-15-2009, 10:48 AM #3
09-15-2009, 11:10 AM #4Junior Member
- May 2009
- canada
So basically you need it to be double adjustable if your more serious like at the track and stuff. I m not going to be doing those adjustments my self so i guess ill cheap out to lol
09-26-2009, 06:41 AM #5
double adjustable makes it easier to adjust because you don't have to remove the bar when it comes time to adjust it.
Question: Adjustable Lower Control Arms & Panhard Bar
By 98BlackMambaWS6 in forum Suspension and HandlingReplies: 27Last Post: 07-31-2012, 04:36 AM -
Question: Lower control arms and panhard bar
By 98maro in forum General HelpReplies: 17Last Post: 04-08-2010, 06:15 PM -
Question: lower control arms and panhard bar
By SSMOKEshow in forum Suspension and HandlingReplies: 9Last Post: 04-09-2008, 09:41 PM -
LGM G2 ALLOY, rod ended panhard bar & lower control arms
By refusenik in forum Parts For Sale / TradeReplies: 32Last Post: 08-11-2007, 07:47 AM -
Wanted: Adjustable panhard rod and rear lower control arms
By smkeater911 in forum Parts Wanted / TradeReplies: 0Last Post: 02-18-2006, 08:40 PM
