Results 1 to 20 of 29
Thread: The FOAM.......
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    The FOAM.......
    Whats the general consensus on ''Sea foaming'' your engine? To cleanout carbon build up on top of pistons etc?
    Greensboro, NC
    2002 Trans Am WS6 M6
    A lot of us here use it.
    Oct 2001
    Colorado
    95 Z28
    I used it on my old jeep cherokee. Worked fine, just be sure not to suck it in too quick and risk hydrolocking the motor. Use a small vacuum line and take it in slowly while someone else gives the engine some throttle. Then run the second half through the fuel system.
    Wisconsin
    2001 Camaro SS M6
    I use it with great results (Tore apart my motor for H/C after using it and you could eat off of it)
    I use it like this (2 bottles)
    1/2 bottle in the oil for 50 miles before the oil change
    1/2 bottle through the brake booster vaccum line (Use it like 5.0This has said)
    1 bottle in the gas tank after fill up.
    I do this once a year and did it right before my build and used with PP and oil changes every 3000 miles, my motor had not a hint of dirt in it. My friends and myself were shocked how clean it was
    Jul 2012
    NorCal
    2002 Camaro SS M6
    Thats what i thought!! I did it once and was not too sure what anyone else`s thoughts were?It smoked afterwards like a mutha! but the smoke was not dark or black so i guess my cylinders were not that carbonized huh?
    Wisconsin
    2001 Camaro SS M6
    Another key thing that I do is when I suck it through the brake booster line, I kill the motor right after the last of the bottle goes in. I then let it sit 20 minutes soaking before I fire it up. When I fire it up I gas it pretty good or go out for a quick hard run to break up anything in there and burn up all the Seafoam.
    Probably 100+ ways you can do this but I'm happy with how I do it so
    Last time I used it had an RX 350 behind as I was clearing it out Just got the Subaru then and was a lil dirty then
    Wisconsin
    2001 Camaro SS M6
    When I used it on my old Corsica everyone that was behind me (Approx 3 cars) had a nice lil smoke screen to drive through
    Could only imagine what they thought was going on
    Jul 2012
    NorCal
    2002 Camaro SS M6
    No actually i like and agree with your way Ive read up on it online and thats basically what they suggested! Thanks....
    Indiana
    2009 Silverado Z71
    2003 Corvette MN6 Black
    I remember reading a thread on here once not to Sea Foam your car using the Brake Booster line, because the way our intakes are shaped it wouldn't reach all of the ports. Instead to suck it from the PCV hole on the intake in the front. Also remember hearing Mopar Combustion Chamber Cleaner is way better.
    Wisconsin
    2001 Camaro SS M6
    If you are worried about the intake then just open up the throttle body and spray Seafoam Deep Creep in the intake. I've heard seafoam is kinda harsh on gaskets but I'm not worried. Also heard AutoRx is better stuff but again, I'm not worried.
    Jul 2012
    NorCal
    2002 Camaro SS M6
    Not sure about it not reaching all the ports and also part of the "Seafoaming" procedure includes the T/B with Deep Creep ,Its best to take the T/B off and really clean it out good ! The reason i would take off so get all the carbon build up off between the T/B housing and butterfly flap PLUS if you just use the red thin straw type applicator that comes with the can it has a tendency to shoot off the can into your T/B and into the galley,I had this happen to me It took me a while to retrieve it but i did w/o having to remove my intake manifold!
    Down the PCV Port does seem to work better. Also just plain water works well also
    Jul 2012
    NorCal
    2002 Camaro SS M6
    Water???
    Quote Originally Posted by gtp231 View Post
    down the pcv port does seem to work better. Also just plain water works well also
    Oct 2001
    Colorado
    95 Z28
    Quote Originally Posted by SuperSSguy View Post
    Water???
    Yes. People have been doing it for a long time. In small amounts it can act to "steam clean" combustion chambers.
    Water???
    Look up meth injection systems, they are mixed with water.
    Like 5.0 said in "small amounts"
    Me personally no way would I risk it.
    Let me clarify my previous post - I wouldn't use water alone. Meth injection with a water mix solution has been proven like N2O to be used as a great power adder, but it can like N2O when miss or overused lead to engine problems.
    Suck it through your slurpee straw and like sea foam don't try and suck in a lot in one shot and its fine
    Jul 2012
    NorCal
    2002 Camaro SS M6
    Oh i know of and know how ''meth -injections'' work Its a cool way to make extra power but i meant ive never heard of just water,,me too would NOT do that..just saying
    Jul 2012
    NorCal
    2002 Camaro SS M6
    Yeah "mixed with water''.
  1. Sea Foam
    By badboy10 in forum General Help
    Last Post: 02-27-2014, 08:42 PM
  2. Question: Anyone know what this foam is?
    By 02z28ttop in forum Camaro / SS
    Last Post: 09-02-2012, 02:41 PM
  3. Question: Sea-foam
    By mastertairium in forum General Help
    Last Post: 07-16-2012, 07:07 AM
  4. Question: sea foam
    By johnny 5 in forum General Help
    Last Post: 02-06-2011, 01:48 PM
  5. Sea Foam
    By 99M6Z28 in forum Internal Engine
    Last Post: 12-18-2005, 10:23 AM
