Results 1 to 20 of 28
Thread: Sea-foam
    Junior Member mastertairium's Avatar
    Mar 2012
    Fort Bliss, TX
    1999 Camaro Z28
    Sea-foam
    So my neighbor is a backyard mechanic, does real good with all his work. He swears by this sea foam stuff. Says it will get rid of any ticking or knocking that u might have. Apparently u have to pour some in u'r gas and some in u'r engine oil, then let it run through the system. All the while u get this black smokt out the tail pipes. Has anyone else heard of this stuff? And if so does it really work?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Myself and other members here use it. Works very well.
    Mar 2012
    Fort Bliss, TX
    1999 Camaro Z28
    Ok, so what exactly does it do though?
    Member chris1974's Avatar
    Jan 2012
    Houston
    Bright Red
    1998 Firebird Formula LS1
    I've never used it. Saw someone fog out a neighborhood using it though. I've heard nothing but good things about it.
    REAPER Z28 reaper ws6's Avatar
    Apr 2009
    Tyler TX
    Navy Blue Metallic/Black
    02 camaro z28/01 wife t/a
    is good i use it on all my cars, what you do you buy two cans, poor a whole can into your gas tank , then poor half of the other one into your oil and the other half into a vacum line like the brake buster line, let it sit for like 20 minutes then turn it on and drive the crap out of it allot of black smoke should come out and thats all the gunk in your fuel, system and it cleans the valves and all the oil system as well, you can fell the hp being restore, there are allot of videos on youtube on how to do it.
    Mar 2012
    Fort Bliss, TX
    1999 Camaro Z28
    Are there any down falls to it though? I mean it won't affect and plastic or rubber, i really think its something i need to do. Im just a little hesitant about it, would really hate to screw up my engine.
    Member 88gtman's Avatar
    Mar 2011
    Pensacola
    It is petroleum based and will not harm the plastic or rubber. Personally I only use one can. Pour half in the full tank, and slowly put the other half through a vaccuum line. I don't put it in so fast that it will stall the engine. Some put it in with there oil, but not me. Putting something that foams in with my lubricant just doesn't seem good. JMO.
    Insurgent Hunter dethinboots's Avatar
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    sea foam has prolonged the life of previous cars ive had and makes them drive almost like new. the only possible downside is having to change your oil at maximum 100 miles after introducing it to your crankcase. breaks down all the nasty gunk in there, and who wants to drive with all that swirling around. I use this in the goat every 3 to 5k.
    Jan 2012
    Houston
    Bright Red
    Could it possibly foul out any sensors or clog injectors or anything? You know...all of that junk trying to exit the engine...
    North Jersey
    2004 GTO M6
    Quote Originally Posted by chris1974 View Post
    Orlando, FL
    Mean Black
    i personally use it every 20k and i haven't had a single problem. The 1st time you use it you will fog the neighborhood. I use one can in the fuel tank and half in the brake booster line. The other half in the engine before Im fixing to change oil. The 1st time I use it I noticed an increase in throttle response and idle.
    Sounds like I need to throw some in the TA.....
    Member JacobLS1's Avatar
    Feb 2011
    Colorado
    1998 Z28
    I love seafoam, just seafoamed mine today. didnt smoke too much. I was curious about their "Trans Tune" product.
    Mar 2012
    Fort Bliss, TX
    1999 Camaro Z28
    Guess maybe i will pick some up and give it a try
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Never used it but I may give it a try now.
    Apr 2009
    Tyler TX
    is good to do it before a tune up, cause after your done seafoming you will have to change your oil before 300 miles and spark plugs as well
    use it on a full tank or less then?
    Orlando, FL
    Mean Black
    One can with a full tank of gas and one half in the oil and the other half in the brake booster hose.
    Member FMBL's Avatar
    Mar 2010
    NRH, TX
    1998 Z28
    Quote Originally Posted by reaper ws6 View Post
    You should not have to change the plugs after using seafoam.
    Orlando, FL
    Mean Black
    Quote Originally Posted by FMBL View Post
    correct, i never had to change spark plugs after it.
  1. Sea Foam
    By badboy10 in forum General Help
    Last Post: 02-27-2014, 08:42 PM
  2. Question: Anyone know what this foam is?
    By 02z28ttop in forum Camaro / SS
    Last Post: 09-02-2012, 02:41 PM
  3. The FOAM.......
    By SuperSSguy in forum Almost Anything Goes
    Last Post: 07-23-2012, 06:05 AM
  4. Question: sea foam
    By johnny 5 in forum General Help
    Last Post: 02-06-2011, 01:48 PM
  5. Sea Foam
    By 99M6Z28 in forum Internal Engine
    Last Post: 12-18-2005, 10:23 AM
