    Member TA98's Avatar
    Mar 2009
    Maryland
    12 bolt swap Driveshaft?
    Will i need a new driveshaft when switching rears? I plan to swap in a month and already plan to get new wheels(narrowing the rear 2.5 or 3 inches on each side), and wasnt sure if i would need a new driveshaft or not.
    I believe I ended up with a shaft about 5/8" shorter if I recall. Give me a minute and I'll post a link.
    And the thread where I asked the very same question: http://www.ls1.com/forums/f8/do-i-ne...eshaft-130149/
    Arizona
    I've never needed a new shaft on the conversions I've done unless you use the 9".
    I just built a 12 bolt for my wifes car, used the stock shaft with an adapter joint for the 1350 yoke.
    Mar 2009
    Maryland
    ok cool. I guess I can test fit and see if its to close to the trans or it binds. By adapter joint you just mean a U joint with larger cups that bolt into the yoke, right?
    Arizona
    Yep
    May 2010
    Orlando
    2001 Trans Am WS6
    I used a factory drive shaft with my Strange 12 bolt in my TA (6spd) with no issues. The yoke did extend further into the trans but never appeared to bottom during 6 months of street driving. Good Luck!
  1. 63 corvette ls swap question-driveshaft
    By 63vettels3 in forum LSx Retrofit and Swap
    Last Post: 10-19-2016, 05:14 PM
  2. For Sale: Aeromotive Fuel Stuff, Built 4L60e, 10 Bolt, driveshaft
    By ICRAZY6 in forum Parts For Sale / Trade
    Last Post: 06-23-2012, 07:58 AM
  3. Question: 10 bolt swap?
    By Firebirdformula99 in forum General Help
    Last Post: 11-24-2010, 08:03 AM
  4. Question: 12 bolt STRANGE swap-A4/M6
    By joedude02 in forum Drivetrain
    Last Post: 10-13-2009, 01:19 PM
  5. 12 bolt swap
    By maroca in forum Drivetrain
    Last Post: 02-22-2008, 11:34 AM
