Thread: 10 bolt swap?
    Nov 2010
    orlando fl
    firebird formula 99
    10 bolt swap?
    hey guys i posted before and was told the best way to go would be a 12 bolt or a ford 9in well i was looking online trying to find a used 12 bolt that will bolt right in i dont want to have to modify one and on top of that im not sure what 12 bolt will work with the torque arm if you guys could help out it would be great i dont race my car much and it only has bolt ons im just looking to get rid of that crap 10 bolt
    thanks
    blah '02 WS6's Avatar
    white deer, tx
    '02 trans am ws6
    Have you looked into a Strange S60 or a Moser?
    '02 ws6.....mods? nope
    You pretty much need an F-body specific 12 bolt as nothing else has the torque arm provision. As stated, both Strange and Moser manufacture these axles.
    USA
    Velocity Yellow
    2008 Corvette Z06
    General rule of thumb for the 10 bolt swap.
    A4 go with a 12 bolt
    M6 go with a 9 inch
    This of course is if you plan to be putting some serious power to her and taking her to the strip.
    I went with the Moser 9 inch and couldn't be happier.
    2018 Tahoe - Silver - OEM
    East of Cleveland, Ohio
    99 WS.6 - Modified
    There are actually many manufacturers who make 9", 12 bolt, or Dana 60 rear ends for f-bodys. As stated Moser, Strange, Midwest Chassis are some of the bigger names. Unless you are putting major power through your drivetrain, a Dana 60 is usually overkill and is about the heaviest weighing between the 3. Most manufaturers offer many options - as in keeping your stock brake setup, sway arm mounts, ect. Good luck with the swap.
    Member Rmaverickz28's Avatar
    Oct 2010
    CA
    pewter, silver
    02 Z28/00 SS450rwhp
    I hade read this in a car carft mag, 12 blot vs.9 inch, first off yes the 9in is stonger cus of the pinion angle, thus makeing it stonger and easyer to work on, but the pinion angel on the 9in loses 2-3% power vs an 12 blot, and the dana 60 is the heavest and stongest of the two but have the most power loss as well, the 9in is only 2% stonger then the 12 blot you wont belive this but the 10 blot has the best power loss of them all put weak as hell so it like dude said depens on what you want to to with the car if you want serios draging go with dana 60 (I mean like outlaw class) but the 9in or the 12 blot will be just fine, and as far as the rule of tumb goes its
    3,73A4
    4.11M6 (9in or 12 blot)
    I have a moser 12 blot with 3,73 when I put in the car felt like a more richer refined you cant go wrong with an 9in but can we keep it mind its made by FORD!!! yes it stonger but we have better powertrain loss and JUST as stong as the Ford, So have to ask your self do you want to sell out to the dark side just to have a little bit stonger rearend, and easyer to work on, or keep your parts in the genral's house and have better powertrain loss, food for thought! I LOVE MY MOSER 12 BLOT!!!
    2002 Camaro Z28 Stock Ls1 longtube Slp Headers,Slp Y-pype, Flowmaster 80 series ,Level 10 Trans, Moser 12 blot 3.73s 33-spine axels tru-track posi, 335rwhp 345rwtq (STOLEN!!! 02/2011)
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    It all depends on what your goals are for your car.
    In most cases, the 12 bolt will be strong enough. I have seen both 12 bolts and 9" rear ends meet their demise. Most likely though, the 9" broke due to improper set-up, maintenance, or improper suspension set-up.
    Wheel hop is a rear-ends nightmare.
    With everything, there is always a compromise.
  1. 12 bolt swap Driveshaft?
    By TA98 in forum Drivetrain
    Last Post: 07-13-2012, 02:35 PM
  2. Question: 12 bolt STRANGE swap-A4/M6
    By joedude02 in forum Drivetrain
    Last Post: 10-13-2009, 01:19 PM
  3. 12 bolt swap
    By maroca in forum Drivetrain
    Last Post: 02-22-2008, 11:34 AM
  4. Bolt On Parts - Dyno Proven Bolt-ons - Tech
    Last Post: 10-01-2007, 04:37 PM
  5. Center bolt to Perimeter bolt Heads, Coil Mounting help
    By juiced99ws6 in forum Internal Engine
    Last Post: 03-30-2007, 11:38 PM
