Thread: power steering
    Junior Member Big D Squared's Avatar
    Jul 2012
    winter haven fl
    2000 trans am ws6
    power steering
    Just got a trans am and the power steering is making that rrrrrrr sound and ink what is from the pump is going or just need to be flushed or what idk can anyone point me in the right direction?
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    It sounds like the front pump bearing. Time to change the pump and flush out the entire system.
    Jul 2012
    winter haven fl
    2000 trans am ws6
    How much does the pump usually cost
    You will also want to inspect the fluid carefully. The stock power steering cooler mounted in the upper radiator hose can fail and cross contaminate both the coolant and P/S fluid.
    1st determine if there is a leak and where it is.
    No Leaks: - Pump failure. Replace, I recommend using the local parts stores because most are remand or come from China and are known to fail again within a yr. For a pump I either use gmpartsdirect.com or Rock Auto.
    Leaking:
    1) Check the Alternator - Why, if you have PS fluid all over it your leak is at the reservoir. If leaking here you now have other issues to worry about. Get enough fluid in the alternator you'll be replacing it and possibly the battery too. Ask me how I know...
    2) Check the R&P - is fluid all over the place on the K member. R&P is leaking and needs replacing.
    If at the reservoir - check the O rings on the high pressure hose. Over tighten and they fail. An easy rebuild just need a .80 cent O ring from any parts store.
    Use this thread for help.
    http://www.ls1.com/forums/f6/so-you-...g-leak-151991/
  1. Help: Power steering
    By 1998ss in forum Stereo and Electronics
    Last Post: 09-17-2013, 03:02 AM
  2. I need power steering help
    By transam_00 in forum External Engine
    Last Post: 01-11-2011, 07:51 AM
  3. Question: Power Steering, Manual Rack, Power Steering Pumps-etc
    By TerribleTed in forum General Help
    Last Post: 11-18-2010, 04:37 PM
  4. power steering is no more
    By transamgirl89 in forum Camaro / SS
    Last Post: 08-20-2010, 06:27 PM
  5. power steering?
    By Spikito in forum Camaro / SS
    Last Post: 06-19-2009, 10:51 PM
