Results 1 to 20 of 25
Thread: spark plug wires
04-05-2006, 09:12 PM #1Junior Member
- Dec 2005
- lake in the hills, Illinois
sebring silver- 1999 camaro z28
spark plug wires
is there a difference betweem the msd 8mm wires and the taylore 10.5mm wires?? and whats a good spark plug, just wonderin b/c om replacing them soon..thanks
04-06-2006, 07:51 PM #2Member
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
re:
Will both are quality wires one has a 8mm insulation the other 10.5mm of insulation. I run the Taylor LS1 thundervolt wires I high recommend them. For a replacement spark plug if the car is still mostly stock the stock GM’s are good, but most switch over to NGK TR-55. The NGK T-6 and T-8’s are made for boosted engines.
1998 Camaro SS Hard Coupe Bright Red #1593
Mods: Lots!!, still my daily driver except for winter
383rwhp 370rwft/lbs
1979 Corvette
Mods Lots!!, weekend cruiser
325rwhp and 320rwft/lbs
2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
Mods: Catback, BFI CAI, Winter daily driver
07-31-2006, 01:13 PM #3
A wire's diameter does not mean anything performance-wise. What you should be looking at is conductivity, not MM size.
MSD - 40-50 OHM resistance
Taylor - 50 OHM resistance (Thundervolt Race wires)
Granatelli - 0.05 OHM resistance
07-31-2006, 01:13 PM #4
BTW, I don't have the charts with me at the moment but the stock plugs are around 600 OHM resistance if I'm not mistaken.
07-31-2006, 01:30 PM #5
08-01-2006, 07:41 AM #6Junior Member
- Jan 2006
- VA
WHITE- 2000 CAMARO
I'm with TAYLOR. Summit $49.95
08-01-2006, 12:41 PM #7
Summit has our product for sale too
I have a quick question for all of you. Are you recommending Taylors because you currently own them?
Our product is still relatively new so it'll take time to get good attention to the consumers, but I cannot stress enough that these wires are 100% better than the competition. In the Sept. 2005 issue of Chevy High Performance, they dynoed a Chevy Silverado with several different tests...
Test I - Wires
15.3 HP improvement and 17.3 lb/ft torque improvement
Test II - MAF and wires
26.8 HP improvement and 38.9 lb/ft torque improvement
Test III - Cold air kit, MAF, and Wires
55.05 HP improvement and 45.1 lb/ft torque improvement
08-01-2006, 12:55 PM #8The RookieGuest
really??? Granatelli wires? You are right I haven't heard of them. So makes yours different? What do you different to yours?
08-01-2006, 03:50 PM #9
What sets us apart from the competition is the design. Our Granatelli wires have a thin solid stainless cable, insulated with tightly wound fiberglass-reinforced braids, with a silicone jacket able to withstand 500 degrees F (we have jackets able to withstand 1500 degrees F for special orders).
What I've seen with the competition is they use copper and nickel for their inner core.
08-02-2006, 08:31 AM #10
You may be able to find them on sale at SummitRacing.com. if you do some searching you can find anything for cheap...these readings were done on our wires not OHM resistance per ft.
08-02-2006, 02:07 PM #11
08-02-2006, 02:16 PM #12
08-05-2006, 11:36 AM #13
08-22-2006, 03:14 PM #14
Here's some eye candy for all of you - video of a brand new C6 Z06 testing out our coil-over plugs on the dyno: Click Here
08-23-2006, 06:52 AM #15Junior Member
- Mar 2006
- Louisville, KY
08-24-2006, 12:02 AM #16Junior Member
- Aug 2006
- MD
Red- '02 Camaro SS
08-24-2006, 07:50 AM #17
I was thinking about this yesterday. Maybe GMS or someone running their wires can answer this.
I remember back in the day of getting "resistor" wires to remove engine noise from the radio system. Is that going to be a problem with the 0 ohm wires then?
08-24-2006, 07:18 PM #18
I'm going to be changing my plugs and wires soon, and I'm probably going to just go with the stock AC Delco Wires and AC Delco Iridium plugs. I think the stock wires are more than adequate, and you know they are a quality set. With aftermarket ones you don't always know what you're getting, and the last thing I want is issues.
08-25-2006, 07:53 PM #19
summit has the granitelli wires for 100 bucks
08-26-2006, 05:02 AM #20Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
Are there any gains to be had if your wirezs are shot?
spark plug wires
By jking78 in forum Parts Wanted / TradeReplies: 15Last Post: 02-02-2015, 11:38 AM -
spark plug wires
By 02transamce in forum General HelpReplies: 21Last Post: 03-15-2011, 04:35 PM -
Help: Spark Plug Wires Won't Come OFF!!! HELP!
By Mesterious in forum External EngineReplies: 7Last Post: 05-30-2010, 09:22 PM -
Spark Plug Wires
By WS6ICK in forum External EngineReplies: 7Last Post: 10-09-2006, 08:40 PM
