    Junior Member Mesterious's Avatar
    Feb 2010
    Mississippi
    2002 Pontiac Trans am WS6
    Spark Plug Wires Won't Come OFF!!! HELP!
    Right now I'm doing LT Headers and Poly Motor mounts and I've just got started pretty much. I'm at the Coil Pack stage. I unbolted all bolts from the coil pack and now I have to sit them down some where. Well I would, but my spark plug wires are sucked tight to the freakin spark plug. Do they have vacuum in them or something?? The real question is: HOW IN THE WORLD DO I GET THEM OFF???
    This is why you always, always put a dab of dielectric grease in the boots before installation. Anyway, your best bet is a boot puller but you won't be able to get it on all of them. You can use pliers and other destructive methods of removal as well if you are replacing them. Just put some gloves on or you will be bleeding.
    Feb 2010
    Mississippi
    Apparently they didn't put much of any on my car when it was in the factory getting put together... I will try pliers tomorrow morning defiantly. I will get a wire puller later in the day if the pliers don't get all of them out. Thanks man!
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    try to twist them also. If you can get them to spin a little bit, that will help loosen them up. But when they're stuck, it really sucks. Happens a lot. Try pliers, prying, twisting. Wear some mechanics gloves so you can really rip and tear without worrying about cutting your hands if they slip free just like PaJeff said
    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    If worse comes to worse autozone sells msd plugwires for 60 bucks.
    Pittsburgh
    2008 Hummer H3
    If all else fails you can cut the boots with a (new blade) utillity knife or razor knife. Cut them long ways then yank them out/off..
    You aint havin fun if ya aint bleeding..lol
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    mine were kinda stuck on a little when i messed with them, all i had to do was twist them and they came right off.
    Feb 2010
    Mississippi
    Oh yeah sorry about that guys. I got them off yesterday. I finished my full install today except motor mounts cause I couldn't work on my car tomorrow and I wouldn't be able to drive anything then. Luckily no Y pipe banging. THANKS GUYS!
  1. spark plug wires
    By jking78 in forum Parts Wanted / Trade
    Last Post: 02-02-2015, 11:38 AM
  2. spark plug wires
    By 02transamce in forum General Help
    Last Post: 03-15-2011, 04:35 PM
  3. Spark plug wires
    By sasquatch094 in forum External Engine
    Last Post: 03-24-2010, 02:15 PM
  4. Spark Plug Wires
    By WS6ICK in forum External Engine
    Last Post: 10-09-2006, 08:40 PM
