Thread: bleeding rack and pinion???
07-02-2012, 09:14 AM #1Junior Member
- Jan 2011
- Arlington IL
Dark blue- 2001 trans am
I recently have installed a cardone rack from orielly's and having troubles with it, when I turned all the way one direction after leaving a gas station my power steering stopped working.Then I crawed under the car to check it out I noticed the boots that go over the inner tie rods to the rack look as if there going to explode. I have tried bleeding the system of air but those boots still look as if there full of air. Not sure wat is going on with the power steering system. Any comments would be much oblidged.
07-04-2012, 04:28 PM #2
My guess would be bad seals in the new/rebuilt rack, look in side the boots if any oil then the rack is bad , did you reinstall the small equlizer line which allows the air to equlize from one boot to the other, if not one may build pressure. as to bleeding the air from rack you should slowly turn the steering from lock to lock about ten times which should bleed system ( may need to do this a couple times )
just my guess,JohnnyY2K SS (SLP #239)
Completly STOCK heads/bore/stroke/weight
& NOTHING else ---is stock
"NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
ps: I am not soliticing work as I am retired
>>>info on alignments
http://www.jgruggles.com
07-04-2012, 06:01 PM #3Junior Member
- Jun 2012
- Newburgh indiana
We need pictures !
2002 tahoe 5.3L CAI, tr224 112lsa cam, ls6 springs, 10.4mm plug wires, monster trans stall converter 2,300-2,500 rpm, cat delete, flowmaster exhaust, custom tune by wayne hartwig
07-04-2012, 06:40 PM #4Junior Member
- Jan 2011
- Arlington IL
Checked it out, sure enough seals were bad. Put in another rack, blead the system of air. Seems to be good to go.
07-05-2012, 11:56 AM #5
07-05-2012, 11:58 AM #6
The dealer bled my 01 Camaro over night after replacing my pump after the car only had 30k on it..
If you replaced any of the steering parts with a remaned pieces, be prepared to do it again..
07-05-2012, 04:11 PM #7Junior Member
- Jan 2011
- Arlington IL
The rack was a reman, but no big deal the r+r is pretty simple.
Which rack and pinion?
By huitt06 in forum Firebird / WS6Replies: 4Last Post: 10-29-2014, 04:25 AM -
rack and pinion
By disavowed10 in forum External EngineReplies: 4Last Post: 06-02-2008, 11:47 AM -
rack & pinion
By RLamas in forum Firebird / WS6Replies: 10Last Post: 05-17-2008, 07:37 PM -
Rack and Pinion
By aerojt in forum General HelpReplies: 3Last Post: 07-10-2007, 04:41 PM -
Rack and Pinion WTF???
By lvbroham1 in forum General HelpReplies: 6Last Post: 07-07-2006, 07:11 PM
fixed!
