Results 1 to 18 of 18
Thread: service engine light code
04-05-2006, 06:39 PM #1Junior Member
- Mar 2006
- bakersfield,ca
black- 01 pontiac transam ws6 m6
someone please help and tell me what is wrong with my car od2 code is
PO420 it shows up ywice... it says catalyst low flow restricted or sumthing like that does that mean my damn catalytic converter is out? also i have the flowmaster 80 series crossflow could this have caused this?
04-05-2006, 09:29 PM #2
cat efficiency below threshold....your driverside cat isn't working as good as it should. I had that code and I replaced the cats and haven't had the code in 4 months...before that it would pop up within a day of being cleared. Make sure the cat went bad on it's own though....because other conditions can cause a cat to go bad...like a blown headgasket or running rich. You want to fix the cause...not the effect, otherwise you'll be buying more then just 2 cats
04-05-2006, 09:52 PM #3
First I would swap the rear O2 sensors to see if the code follows that sensor before changing cats. May just be a bad sensor but that's one way to find out. If it's the sensor it'll throw p0430 for the passenger side and if you still get 420 then it's time for new cats.
04-06-2006, 05:58 AM #4pontiac_godGuestYep...for that bank. If it were an O2 sensor then you would throw a code PO13*.
Originally Posted by RYDER661
04-06-2006, 10:09 AM #5Senior Member
- Jul 2005
- Jacksonville, FL
Don't forget about the federal emissions warranty on the cats - most of them get replaced free.
04-06-2006, 11:36 AM #68 years/80k miles. Some dealers will make exceptions, but don't expect it.
Originally Posted by 2001NBMZ28
04-06-2006, 12:32 PM #7Junior Member
- Mar 2006
- bakersfield,ca
i bought my car used at 58,000 miles has 63k now does it still have the federal emissions warranty?
04-06-2006, 01:38 PM #8Senior Member
- Jul 2005
- Jacksonville, FL
Yep, the 8/80 is for the cats and PCM - don't have to be the original owner. Leave the light on and see what the dealer says - most will tell you over the phone diag fee, could be an 02, exhaust leak, physical damage to cat etc. - but I have a couple friends that had the same code and they replaced it free - only issue they had was P0420 illuminated.
04-07-2006, 08:14 AM #9
o2
yeh i'd change the o2's first
04-07-2006, 06:29 PM #10Member
- Jan 2006
- decatur, AL
6.93 at 100.3 mph- 1992 Camaro RS
p0420 does mean the converters need to be replaced
04-07-2006, 10:23 PM #11Junior Member
- Mar 2006
- SF Bay Area
Black- 2002 Trans Am WS6 M6
I've had this code a few times and have thought nothing of it because I knew what the code meant. Is there any reason to replace my cats besides emissions compliance?
04-08-2006, 12:42 PM #12If you don't want to replace them...either gut them or remove them....last thing that you want is a clogged cat.
Originally Posted by GLUMAKER
04-09-2006, 06:34 AM #13pontiac_godGuestHe doesn't have a clogged cat. You'll throw a PO420 for much less a problem than a clogged catalytic converter. It is an effeciency monitoring system that compares the voltage waveform of the upstream O2 sensor to the downstream O2 sensor. If you gut or remove the cat, you'd best not live where you are going to need to emission test because you will be driving with the SES light.
Originally Posted by SeVeReDiStOrTiOn
Just take it to the dealership and have them replace it. It's convered under warranty. They might be relanctant to do it...but still to your guns about it and you'll get a new one.
04-09-2006, 03:52 PM #14Junior Member
- Apr 2006
- United States
Maroon & Silver- 2000 Chevy 2500HD 6.0 V8
I have a 2000 Chevy 6.0. It has dual exhaust straightpipes. My O2 sensor burns out when i put a new one in it. Where can I get the dummy sensor to put in for it?
04-09-2006, 07:30 PM #15Yes I know it'll throw a code just for low efficency...like I said I had the same code and passed cali smog only a month before the p0420 started popping up. Also I never said he has a clogged cat...I said the last thing he wants is one....since it sounds like he planning on just leaving the cat the way it is.
Originally Posted by pontiac_god
And yes you can gut or remove the cats without having the ses on all the time....either get rear o2 sims or have the rear o2's tuned out.
04-09-2006, 07:33 PM #16Also he lives in cali....so the cat warranty is only good for 7yrs/70,000miles....rest of the states it's 8yrs/80,000
04-10-2006, 01:32 PM #17Junior Member
- Mar 2006
- SF Bay Area
Yes, I do plan on leaving the cat the way it is. I'll change it when I have to deal with smog.
04-10-2006, 02:32 PM #18Senior Member
- Jul 2005
- Jacksonville, FL
Assuming you have precat and post cat 02's like we do stock, 02 sims will work for the post cat sensors - if it's a front one something else is going on and sims won't work.
Originally Posted by jimbo4069
Question: "Service Engine Soon light" Got a P0430 code
By gymrat11 in forum Camaro / SSReplies: 8Last Post: 01-09-2014, 07:42 AM -
Help: Service engine soon code P0420
By Black WS-6 in forum General HelpReplies: 4Last Post: 09-13-2010, 08:02 AM -
Check Engine light vs. Service Engine light
By bigrig73 in forum Computer & TuningReplies: 1Last Post: 04-20-2010, 06:11 AM -
Service Engine Code help
By draggo in forum General HelpReplies: 7Last Post: 04-16-2009, 05:19 PM -
Help: Service Engine Soon Light.engine Code No.7missfire
By josh68 in forum General HelpReplies: 10Last Post: 07-16-2008, 08:47 AM
