06-30-2012, 10:17 AM #1
2000 Formula Firebird 570 HP 47k original miles
Selling my car its very clean very fast garage queen . 47k original miles
Only the best of the best was used in the build of this car
Only the best of the best worked on this car, Simple Quick , LG motor sports , etc
I have all receipts on the parts and labor put into the build
Car is still very street legal, and passes inspection no problem
THE MOTOR WAS BOUGHT NEW FROM HKE EVERYTHING WAS DONE AT 41800 MILES THE CAR HAS 47K ORIGINAL MILES
The car was built to go straight with approx, 60K parts and labor put into this build .
The Car runs 6.9 flat @ 96 MPH with a 144 60 ft with only a 15" rim at 27 PSI car hooks hard
....ALL MOTOR , Never any power adders on this car..
I WILL DO PARTIAL TRADE FOR A CHEVY EXT CAB SHORT BED V8 2003 UP or Tahoe ( NO 4X4 ) NOTHING OVER 115K AND CASH.. WILL depend on truck value
Motor
383 stroker 10:9.1 comp. HKE built
Scat 4340 crank 4"
4340 H-beam Rods 6.125"
Hell Fire rings
All NEW ARP hardware used
HEADS
AFR 205 Milled to 62cc $2500 for head work over price of heads
CAM
G5XE by LG motorsports 600/610 lift 232/238 @50 - 115 Lobe Sep.
TRANNY
RPM Stage 4 4L60E Will handle 750 HP
Precision 4000 stall
B&M Cooler with Cooling Fan
Polyurethane mount
REAR END
Moser 12 bolt
33 Spline Axles
Detroit Tru Trac locker
373 Gears
4 Channel ABS
Exhaust
Kooks 1 3/4 SS longtube Headers
Kooks SS Y-pipe with high flow cats
Corsa Premium Cat back with Dual tips
SUSPENSION
Front
BMR Tubular K-member
BMR drive shaft loop
Hotchkis Subframe connectors
BMR upper A-arms
BMR lower A-arms
Stock springs Bilstein shocks
Rear
BMR lower control arms
BMR adjustable torque arm
BMR extreme anti-roll bar
LG motorsports Double adjustable pan-hard bar
Stock springs
Bilstein Rear shocks
Hood
Suncoast Creations WS6 Ram Air with heat Extractions
Suncoast Creations LT1 style ram air box
ALL BRAND NEW PARTS LISTED IN BUILT
LS7 lifters
New Style LS6 oil pump
ATI Balancer
TCI flexplate
Hardend push rods
Yellow Terra Ultralite Hyd roller rockers 1.7
dbl roller chain
36lbs injectors ( FAST )
fuel rail kit and Fuel line conversion kit ( FAST )
MSD blaster Coils
MSD Plug wires
NGK TR-6 Plug
Walbro (255) pump
102 Intake ( FAST )
102 Throttle Body ( FAST )
160 Thermo
The motor was installed at 41800 miles
I had Every new put on car
every sensor
hoses
belt
alt
water pump
everything on car was bought new ..
Even had dealership install brand new motors put in both doors and both headlight motors that was $850 parts labor
Car Dyno 450 hp 425 torque 570 at fly wheel
For More information full details with Video etc. please call me at 817-233-2190 $16000 obo
06-30-2012, 10:23 AM #2
07-02-2012, 06:45 PM #3
,HERE IS A LINK TO EBAY
Pontiac : Firebird Formula Coupe 2-Door Pontiac : Firebird Formula Coupe 2-Door | eBayLast edited by BA2000SS; 07-02-2012 at 07:22 PM.
07-09-2012, 08:24 PM #4
In need of truck Im dropping price of car cheap.. $14500 takes car.. 47k original miles 60k parts and labor in this car. still passes inspection runs 6.9 flat in 1/8 This is giving the car away. 570 hp
2000 Pontiac Firebird Formula 5.7L 87k miles $8799.00
By bestman77 in forum Vehicles For Sale / TradeReplies: 0Last Post: 10-29-2012, 01:14 PM -
2000 Firebird Formula 45k Original Miles
By BA2000SS in forum Member's RidesReplies: 7Last Post: 04-21-2012, 07:18 PM -
2000 ss camaro 56,000 original miles 12,000
By pokey in forum Vehicles For Sale / TradeReplies: 0Last Post: 09-03-2011, 06:32 AM -
For Sale: 1996 Firebird Formula - Original Owner
By BADATTA2UD in forum Vehicles For Sale / TradeReplies: 2Last Post: 06-27-2009, 03:44 AM -
2000 Firebird Formula - Must See! Original Owner!
By mike.vaughan in forum Vehicles For Sale / TradeReplies: 6Last Post: 07-18-2006, 03:34 PM
