04-21-2012, 10:06 AM #1
2000 Firebird Formula 45k Original Miles
Whats up from Tx. DFW
2000 Firebird Formula hardtop Pewter
Just wanted to share my new Ride I picked up from my buddy I been waiting 8 yrs on this car for him to sell it to me .
Now as he is 64 yr young. He bought the car back in 2004 with 36k miles 8 yrs later car has 45k miles and after $60,000
to build car to its current state parts, labor, tune.. I am the new proud owner of this Awesome car.
The car is very street able. still passes inspection only 373s . But the car runs 6.8s in the 1/8th all motor N/A ( approx 10.7 - 10.8 1/4 mile )
144 60 ft @ 96 MPH on a 15" rim with 27 lbs
How the car looked when i bought it ... Dont get me wrong it was a tough look and i liked it .. But I wanted to get the car looking Custom more than Race look
04-21-2012, 10:11 AM #2
I made a list of the parts on my car.
I'm sure there is some things left out but for the most part
Motor
383 10:9.1 comp. HKE built
Scat 4340 crank 4"
4340 H-beam Rods 6.125"
Hell Fire rings
All ARP hardware
HEADS
AFR 205 Milled to 62cc
CAM
G5XE by LG motorsports 600/610 lift 232/238 @50 - 115 Lobe Sep.
TRANNY
RPM Stage 4 4L60E with a Precision 4000 stall
B&M Cooler with Cooling Fan
Polyurethane mount
REAR END
Moser 12 bolt with 33 Spline Axles
Detroit Tru Trac locker
373 Gears
4 Channel ABS
Exhaust
Kooks 1 3/4 SS longtube Headers
Kooks SS Y-pipe with high flow cats
Corsa Premium Cat back with Dual tips
SUSPENSION
BMR Tubular K-member
BMR drive shaft loop
Hotchkis Subframe connectors
BMR upper A-arms
BMR lower A-arms
Stock springs Bilstein shocks
Rear
BMR lower control arms
BMR adjustable torque arm
BMR extreme anti-roll bar
LG motorsports Double adjustable pan-hard bar
Stock springs
Bilstein Rear shocks
Hood
Suncoast Creations WS6 Ram Air with heat Extractions
Suncoast Creations LT1 style ram air box
LS7 lifters
New Style LS6 oil pump
ATI Balancer
TCI flexplate
Hardend push rods
Yellow Terra Ultralite Hyd roller rockers 1.7
dbl roller chain
36lbs injectors ( FAST )
fuel rail kit and Fuel line conversion kit ( FAST )
MSD blaster Coils
MSD Plug wires
NGK TR-6 Plug
Walbro (255) pump
102 Intake ( FAST )
102 Throttle Body ( FAST )
160 Thermo
When the motor was installed at 41800 miles
I had Stall sent in for flush and checked through Precision
I had Tranny gone through
Rear end gone through
Every sensor replaced .
all hosed
belts
alternator
water pump
everything on car was bought new ..
Even had brand new motors put in both doors and both headlights just because
Car Dyno 450 hp 425 torque Approx. 550 at crank
Still has Air ( SMOG ) Cats only 373s and still passes inspection as well.
04-21-2012, 10:16 AM #3
Ok as of this past week this is the Cars Transformation
These first couple pix with new wheels
04-21-2012, 10:21 AM #4
These Pix are now of the Final Changes of the car. Just a few visual mods nothing over the top but wanted to break up the plainness of the car.. Let me know your guys thoughts good or bad .. The Fender Stripes can be Removed as well..
Painted Calipers red
Smoked Tail lights ( yes forgot 3rd brake but doing it tomorrow )
Added Fender Stripes
and added Ram air to hood in Factory Location ( close as i thought was anyways )
And Final Pix
04-21-2012, 10:24 AM #5
04-21-2012, 10:42 AM #6
Couple Vidz
Sound Of Exhaust and other to see the Suspension working, even letting the car roll out then a little gas then to half throttle spinning 2 car lengths marks how it still pulls up in the front .. This is still with stock springs Its the only left stock though
04-21-2012, 11:30 AM #7
Looks good overall. Not a fan of torque thrust wheels, seems like everyone has them. Nice car though man.
04-21-2012, 07:18 PM #8
Thanks for Comps
For sure on the TT wheels. I searched for a month for a custom set of wheels for this car Besides the TT wheels because of that reason. But I wanted a 315 in the rear Most wheels I looked at and I looked at a lot was only up to 9 wide at 17" and wanting deep dish, but after looking and looking I did end up with the TT but instead of doing TT2s as it is the most common I did the TT M AR 105 just to be a little different. But over all I like them its not what I pictured in my head but its a pretty decent stance / look. I would really like to do a 1.5 lower on the car but with all the suspension done to the car i would really be throwing all that out the door doing the drop to the car. So i'll just keep the stock springs on it Im thinking about going out to the track with the car all back custom ( stock looking ) with spare tire back in . rear seats back in CD changer back in and the factory front seats back in and the bigger wheels . just to get a Video up . With the very first picture i posted of the car with the Hoosiers @ 27 psi the car launches hard with a best of 144 60 ft. average is 145 - 146 60 ft Running a 6.89 Im sure I cant get that good of a 60 ft with these Nitto but If I can get a 7 flat to a 7.10 flat I would be happy with the weight i added and bigger wheels tires etc.
2000 Pontiac Firebird Formula 5.7L 87k miles $8799.00
By bestman77 in forum Vehicles For Sale / TradeReplies: 0Last Post: 10-29-2012, 01:14 PM -
2000 Formula Firebird 570 HP 47k original miles
By BA2000SS in forum Vehicles For Sale / TradeReplies: 3Last Post: 07-09-2012, 08:24 PM -
2000 ss camaro 56,000 original miles 12,000
By pokey in forum Vehicles For Sale / TradeReplies: 0Last Post: 09-03-2011, 06:32 AM -
For Sale: 1996 Firebird Formula - Original Owner
By BADATTA2UD in forum Vehicles For Sale / TradeReplies: 2Last Post: 06-27-2009, 03:44 AM -
2000 Firebird Formula - Must See! Original Owner!
By mike.vaughan in forum Vehicles For Sale / TradeReplies: 6Last Post: 07-18-2006, 03:34 PM
